Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
We have a frigidaire front load washer, which worked fine for 7 years. Since yesterday it no longer seems to get a rapid final spin, and as a result the clothes are too wet for the dryer. The model is called an 8 cycle Tumble action washer.
    Brigadier General:
  • 8,619 Answers
Hi
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Please accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 23, 2009
Model #ftfb4000fs1 frigidaire front load washer will not go into final spin --- drains but will not spin dry
Just had this problem last week. The problem was the door switch, which made no sense to me since the drum still turned on the other cycles. But the repair shop replaced the ($76!) switch and the machine now works fine.
Oct 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire front loader washer makes a very loud knocking sound during the spin cycle before the final rinse. It intensifies the longer I allow it to spin. I have to shut it off before the cycle is...
from your description, it sounds like your washer is already broken - to check, open the door and reach your hand into the tub at the front top. push up. if the tub moves more than a fraction of an inch, the bearing and/or spider are toast. last time i checked, the PARTS were in the neighborhood of $450 and it's a BIG job! [read that: big labor bill]. this is a common problem with these machines and it's probably time to get a new washer. sorry!
Aug 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Frigidaire front load washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
