Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Poulan 2 cycle gas trimer or weed eater
It leek gas from cap and stop runing leeks gas out of top small hold on top off cap ithink it a vent hole thank you
  • 20 Answers
Replace the cap. they are not expensive.
Posted on Oct 16, 2010
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the oil and fuel ratio for the poulan leaf blower
Also check the gas cap on a lot of small engines. The ratio is often stamped on the cap
Mar 29, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
gasoline. Before operation, gasoline must be
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Poulan 14" chainsaw, fuel coming out of fuel cap vent
The fuel cap has a rubber check valve in the top. This check valve allows air to enter the tank so fuel can flow. Much like the vent on your gas can. Sounds like the check valve in the cap is stiffening and not flexing. Best bet is to buy a new cap. Most caps like that sell for less than $3.
Feb 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
456 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
