Question about Ariel Clearview - Pedometer with clear acrylic cover
Need to know how to set my Ariel Clearview Pedometer. Could use some instructions.
Skmei # 1058 Pedometer watch - I didn't receive an instruction manual with my watch. I need some instruction to help set the watch...
Hi Keith
The guy in this video finds a paper manual in his package.
You can probably freeze frame it and take a screen snapshot of th manual. Cmd Shift 4 on a Mac places the screenshot photo on the Desktop
Good Luck SKMEI 1058 Waterproof Pedometer Heart Rate Wrist Watch
pedometer how to use YouTube
Mar 14, 2016 | Watches
When does the clearview pedometer reset
I'm responding 'cuz my Clearview pedometer remains something of a mystery to me, too. So I apologize, right off, about the length and confusion in this procedure. Maybe someone will add a simpler, comprehensive list of commands.
W/o access to a user manual, here is what I've learned about it. Barbara, I didn't think it reset itself... maybe you can explain. I did find that when I hit the "reset" button on the back (to the left of the belt clip), it resets the Step (number taken), Mile (distance traveled), and Kcal (calories burned) to zero. One click for all-three together.
More SETTING steps: The menu is a vertical column to the right of the digital display (from top to bottom: Step, inch, LB, Mile, Kcal). As you scan down the menu, look for the teeny > arrow pointing at one of the functions. Normally the arrow skips from Step, to Mile, to Kcal. If you've been using it, and there are numbers in these fields, you can manually reset these to zero by pressing the "reset" button. Those 3 fields should now register "0" when you scan through the modes as before. I believe this does not reset your stride or weight settings.
These other 2 modes: inch (length of YOUR step), and LB (YOUR weight = this helps in calculating your calorie consumption... I think) were a bit tricky to reset to MY body. I managed to select those modes and enter my own data somewhat haphazardly, by simultaneously pressing the two buttons on the right (Mode, and Set); and then (sometimes, but not necessarily?) pressing the Set button alone. Either way, if you're lucky (!) you'll eventually get a blinking number and the arrow > indicating which field you're in: inch, or LB.
If it is the inch field, it will read 0, or something like 30 (your stride in inches). If you want to change it, press the SET button repeatedly (lower/right) to INCREASE the number in the field. Apparently you can't lower the number directly - if you instinctively press the upper/right button (MODE), it just closes the setting function.
So in order to set to the length of YOUR step, keep pressing (or you can hold it down) until you reach your stride length... it continues up to 120 inches (!!) before restarting at zero. I haven't figured out why it opens in inch, or in LB, but by randomly pressing both rt-hand buttons, I can eventually get into each of the two fields. The weight settings in LB also adjust only upward by pressing the SET button (that is, once you get the field to open). You may have to go to 150# (its max. setting) before you can begin at zero again. Last weird note: When I can't seem to get into these fields at all, I have had some success by pressing and HOLDING the SET button until the reading (usually 0, by then) blinks off and then on, once. Then you can proceed with the other steps.
Mar 24, 2014 | Ariel Premium Supply Clearview Pedometer
Is the Ariel Clearview Pedometer waterproof?
No it is not unfortunately a lot of pedometers and bands are not.
Do you know if the Fuelband is I have that one and am trying to see if I can swim with it
Aug 05, 2013 | Ariel Premium Supply Clearview Pedometer
Aldi Crane pedometer. Where can I get instructions?
[PDF]AU4-PF-6LA - Aldi
https://www.aldi.us/.../1.1.14_Crane_Heart_Rate_Monitor_Watch_...
ALDIFitness watch with speed and distance tracking. Pulse measuring without chest strap. Operating instructions. Item No.: AU4-PF-6LA/6LB. Issue: January 2014.
[PDF]Getting Started: Setting Up Your Pedometer
www.whoi.edu/fileserver.do?...
Woods Hole Oceanographic InstitutionGetting Started: Setting Up Your Pedometer. Starting your walking program is easy! Use these simple instructions to setup your pedometer and walk your way to ...
Tanita PD637 HANDHELD MOTION PEDOMETER Repair ...
www.dqrkc.com/support/p3651266-tanita_pd637...pedometer/page-4
Tanita PD637 HANDHELD MOTION PEDOMETER - Page 4 - Recent ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 308 Snapshot Pedometer Repair Questions ...
www.dqrkc.com/support/p3642406-sportline_308...pedometer/page-8
Sportline 308 Snapshot Pedometer - Page 8 - Recent Questions, ... Fitbit charge HR users manual ... No instructions came with aldi crane pedometer.
Sportline 310 Qlip AnyWear Pedometer Repair Questions ...
www.dqrkc.com/support/p1496572-sportline...pedometer/page-8
Jul 31, 2013 | Exercise & Fitness
Need instructions for sportline 343 pedometer
Sportline has the manuals for many of their pedometers on their product page. For the Sportline 343, see: http://www.sportline.com/products/pedometers/343-talking-calorie-pedometer.html and click on the Product Manual tab. Then click the Download button. The direct link to the manual is http://www.sportline.com/manuals/WV3482BK.pdf .
If you need help with a specific issue with the pedometer, please let me know. I may be able to provide additional information.
Nov 01, 2011 | Sportline Talking Pedometer 343
Leg magic pedometer lost user instructions. Need to know how to reset and use.
L.S.
I lost the operating instructions for my "leg magic" pedometer.
Can you please find one for me.
Tks for your help.
Jan 11, 2010 | Exercise & Fitness
Need set up manual
The instructions are generally the same for various models so here's the one for the pedometer plus..
www.yorksurvey.co.uk/documents/.../silva-pedometer(07-07-16).pdf
Oct 18, 2009 | Silva Exercise & Fitness
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
I need instructions
Here is the sites manual downloads page : http://www.omronhealthcare.com/product/manuals.asp
Hope this helps,
Karlos
Jul 04, 2009 | Omron Healthy Living Kit: Digital...
Reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Apr 24, 2009 | RTO Reebok CS-1 Pedometer
Ariel Clearview - Pedometer with clear acrylic cover Logo
205 people viewed this question
Top Ariel Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Ariel Exercise and Fitnes Expert? Answer questions, earn points and help others
