Question about Bravetti EP4305FS Deep Fryer
I eed reet switch part # WQS-260 - Bravetti EP4305FS Deep Fryer
When I turn my pump on it kicks the breaker. What is wrong with the pump?
sounds like pump motor is rusted you can try to turn by hand when off then try again if not need new motor
Jul 02, 2014 | Pool & Spa
Hi, the sound on my Hitachi switches off after midnight every night. I can get it back briefly if I switch it off/on then it goes again? Daytime it's ok & the Pic is fine! Any ideas?
I would go into Setup and timer/ clock. The sound might well be in off position. You should be able to change the clock to your eeds. Kolbrun
Nov 04, 2013 | Televison & Video
Reetings, My brand new multimeter should be
Not sure where you got 9.63 V from but if think about it - you are measuring about half the value then what you are putting in, so if you are putting in about 14 V you will get about 7 V half rectified (half as many sine peaks). There is nothing wrong with your multimeter and oscilloscope would be better for measurement than DMM.
Sep 01, 2013 | Extech Measuring Tools & Sensors
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
Viper alarm(car) when replace batt(car)alarm goes off like crazy
should be able to close everything on car and just hit the unlock button should disarm if not you may have to hold the valet switch to reet
May 10, 2012 | Nissan Vehicle Parts & Accessories
I n eed 'Arcsoft PhotoBase 4.5 delux' serial.
Serial can be found out only by purchasing that particular product.
Feb 07, 2012 | Arcsoft Computers & Internet
Channels keep chaning
just ensure someone isn;t playing tricks on you here. had a case recently where a neighjbors kid programmed a remote and kept changing channels while he wqs outside window.
Also check your own remote has not got a faulty or sticky button.
Sometimes a computer close by can do this or even an A/C switching in and out. Turn some other things off to eliminate this posssibilty and prepare a gallows for the kid next door if you see him in the street with a remote
Aug 14, 2009 | Televison & Video
Bluetooth
first switch on the blue tooth on your black berry and then connect blue tooth dongle to your computer and check if the connection is established in your computer , blue tooth dongle is usb device ...
Good luck.....
Nov 01, 2008 | RIM BlackBerry 7290
Bravetti EP4305FS Deep Fryer Logo
Top Bravetti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mike
Henry  Thomas
Henry Thomas
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
