Question about Vizio Televison & Video
HDMI output is block due to hdcp authentication failure is showing on screen
4 Suggested Answers
SOURCE: Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Posted on Dec 31, 2008
  • 87 Answers
SOURCE: i recently purchased a blu-ray player and when
That shouldn't make too much of a difference (or maybe im just being ignorant). If the bluray player was cheap, you may need to plug in via rca and then adjust the settings on your player to output to HDMI.
Hope this helps
Nick
Posted on Sep 02, 2009
rikhowell
SOURCE: HDCP AUTHORIZATION FAILURE- HDMI PORT DISABLED
I'm having the same problem with a Samsung cable box, Denon receiver, and Panasonic plasma TV. My issue is temporarily solved by unplugging the receiver for about 10 sec. BUT I AM SICK OF THIS!!!
Other threads I've read on this topic seem to point to the Samsung cable box. Getting new cable boxes from cable company today.
Posted on Jan 30, 2013
What does 'this tv dose not support this programs content. Replace HDMI with component cables to view' mean?
The message has appeared because the TV can not display the hdcp signal that is now used to enable copy protection over the HDMI cable due to the TV being older than the hdcp encryption system (the hdcp is not fitted to your TV )
The two options open to you are
Replace the TV with a hdcp compliant TV
Get a component lead set up
Apr 01, 2016 | Sylvania Televison & Video
How do I convert hdmi to RCA composite?
that outputs HDCP hdmi. you probably cannot convert it on a sony. they use software DRM on the hdmi output. Vivid AV HDMI to Component RGB Audio Video Converter
This supposedly talks to the HDCP on sony. Your mileage may vary.
Jan 26, 2015 | Mitsubishi WS-73909 73" Rear Projection...
We purchased a white HD 1080P Home theatre LED Projector, we cannot get the sound to work. What could be the problem?
The AV may require a separate audio connection. For HDMI, check that resolution (720 vs 1080, etc.) are matched. Could be HDCP handshake failure. Sometimes this can be fixed by powering source & projector off, then back on. Sometimes it is incompatibility between devices, which some claim can be fixed with powered switches (but didn't in my case [with other brands]). HDCP is a bag of hurt.
Jul 30, 2014 | Office Equipment & Supplies
My samsung tv shuts off sometimes & when i can get it back on it reads HDCP AUTHORIZATION FAILURE- HDMI PORT DISABLED
have you had to fry pals the lamp in it. if so the do mite be lulus so try to put it on titer
May 04, 2014 | Samsung DLP HL-P5663W 56" TV
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
My 42 in hisense plasma will say no signal when i try to use any of the 2 hd sources on it???????????????????????????????
Make sure you set the Source to output at 720p or 576p to start with, once you have the signal on the screen, then change the output source to find the modes your TV supports.
A further note, HDMI uses a protocol call HDCP for copy protection, if you are using a HDCP enable device, your TV will not get a signal as the TV will not have given the correct HDCP code to the device.
So, if all else fails after the above, and you are using a HDMI - DVI connector, try a different source unit.
Sep 08, 2009 | Hisense TA42P40M 42 in. Plasma Television
Televison & Video Logo
864 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
