Question about Apple iPod MA446LL/A MP3 Player
Frozen ipod the ipod has frozen how do i get it to turn off or work
  • 342 Answers
Hey i scored you these instructions on how to reset your frozen ipod. Hope its hella useful. Good luck :)
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
If the iPod is connected to a computer and displays any of the following messages you should eject the iPod from within iTunes instead of resetting it:
Connected. Eject before disconnecting Sync in Progress. Please wait... Do not disconnect If your iPod is frozen or won't turn on, the steps to reset it vary by model. You can easily tell which iPod model you have if you're not sure.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on Apr 23, 2009
    Problem Solver:
  • 8 Answers
Im not sure but press the middle button and then quickly press arrow that points right. let me know if it doesn't work
Ipod disabled
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
May 15, 2013 | Audio Players & Recorders
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Feb 19, 2013 | Apple iPod shuffle Second Gen. Silver (1...
How do I fix my frozen e reader
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
Frozen nothing works!!!
Press the Menu Button and the Center button until the apple appears and it will reboot
Dec 25, 2008 | Apple iPod Photo MP3 Player
Ipod nano 8GB 3rd generation FROZEN!
hi,
Firstly, don't worry about your ipod, i had the exact same problem with mine and with 3 of my friends here in athens!
Just leave it frozen untill it drains out of battery,
then try plugging it on your pc and leave it plugged for a while,
after doing that try to open it.
NOTE: my ipod opened after this step and worked properly.
If the ipod still don't works you can do the same as my sister did.
Take the ipod to your sales man and get a software update or replace it (if you are still in guarantee period)
Hope i helped,
Looking forward to hearing from you for further assistance!
Aug 03, 2008 | Apple iPod nano
Ipod screen frozen
Hold the center and menu buttons together for about 7 seconds. It should work
May 25, 2008 | Apple iPod nano 3rd Generation
It turns on but it is frozen
Hi
My gpx mp3 player turns on but can not work
Mar 26, 2008 | GPX ML848B Digital Media Player
Frozen iPod Nano
FOR ALL PERSONS WITH THE FREEZING IPODS AND CANT TURN OFF HERE IS THE SOLUTION
to reset your ipod
switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
rate the solution plzzzz thank u
Jan 28, 2008 | Apple iPod nano
Ipod 30G frozen
wait until your ipod is lowbatt
May 10, 2007 | Apple iPod MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
178 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
