Ariston axd 120 'door' error and F02 error - Washing Machines
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: ariston error code f02
Hi.
Try first disconnecting the power cord or tripping the circuit breaker for five minutes. This will reset the control board in case the error had been only a temporary fault.
If disconnecting and connecting back power does not clear the error, then F02 means Motor jammed or tacho detached.
This means that the main electronic control does not detects any signal from the tacho coil/magnet device attached at one end of the motor, and detecting motor speed.
This basically means that either there is a wiring problem, a motor problem (often jammed), or that the tachogenerator is not working.
Testing is done accessing and testing motor, testing tacho coil, and testing wiring harness to control board.
Try first disconnecting power to reset the machine, if that does not work, call Ariston service at the number listed on the owners manual.
Regards.
Posted on Jan 04, 2010
barkencoa
  • 3463 Answers
SOURCE: F02 error code on ariston 1400
code F02 means motor jammed or motor tacho detached.
Check connections on motor, motor plug, and module.
Hope this helps.
Posted on Jan 16, 2010
Testimonial: "Thankyou for your help. All good."
Hello Ariston Dishwasher not washing machine, I have Error code F03 and now i have F02 what is the problem its brand new. Please help Its an
contact your supplier for support, a new machine should not be presenting you with error codes if it is new and has been correctly installed. The unit will have a warranty that they are obliged to service
Aug 07, 2015 | Washing Machines
Aristhon point f2
F02 - Motor tripped, tachogenerator open circuit or short circuit.
Dado
Aug 16, 2014 | Ariston Technologies Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
Hope this helps.
Jan 15, 2010 | Ariston Technologies Washing Machines
Ariston error code f02
Hi.
Regards.
Jan 04, 2010 | Washing Machines
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ariston Technologies AWD120 13 lb. Washer...
The Ariston ATVF 129 wash machine do not work and post F-02
F02 is a indication that the motor has jammed, and or the tacho has come loose or broken.
The tacho is the magnet at the end of the motor away from the pulley., check this first, you may have to have a new motor fitted.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Nov 04, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
