SOURCE: toshiba satilite a215 s7422 bios password how to cleare
You'll need a special tool that only Toshiba has. I believe you can get yours cleared for FREE if you tell them that all of a sudden out of nowhere you have a bios password. Stick to that story because they've already admitted to the problem with many of their laptops. You'll have to find an authorized Toshiba repair center to take care of it for you. Otherwise I believe they charge around $100 to clear it.
Don't bother to try the cmos battery trick, it doesn't work on your model. The password is stored on an onboard chip.
SOURCE: Bios password for toshiba laptop needs reset
Try This:
Resetting a Toshiba BIOS Password
KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins
1-5-10
2-11
3-17
4-12
6-16
7-13
8-14
9-15
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
SOURCE: Toshiba 300 forgotten password for HDD1 and 2 in bios settings
hi,
there is only one way to get the passwords call toshiba tech support.
Further Queries are welcome
SOURCE: bios password for a10 laptop
it is a well known problem
see these two links
first try cmospswd utitlity then
only option is to short the two pins ... be very careful.. not recommended though If you have never done this kind of thing.
1.http://www.cgsecurity.org/wiki/CmosPwd
2.http://www.laptop-repair.info/toshiba_bios_password.html
SOURCE: reset bios password in satellite 1135
remove the power cable, batter and the cmos battery from the computer, wait a couple of minutes and reassemble. The bios with the password will be reset.
