My RCA converter box stopped picking up any signal
daniel719
  • 240 Answers
SOURCE: RCA CONVERTER BOX ON SONY TV NO SIGNAL
you need a digital antena for the box cost at radio shack about $80
also needs to be pluged in
sounds funny but all of us forget to plug things in now and then lol
regards,
daniel.
Posted on Jan 13, 2009
  • 373 Answers
SOURCE: How do I scan for channels with my RCA converter box
The remote should have a scan button on it.
then the screen go thru it process and it should say done
Posted on Feb 18, 2009
  • 161 Answers
SOURCE: will a universal remote work on a insignia digital converter box?
doublecheck the paperwork for both the converter box and the universal remote. the universal may be too old to be used with your converter. look in the back of the universal's manual to see if your box's corporation has a code you can set.
Posted on Jun 12, 2009
SOURCE: RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Posted on Aug 12, 2009
SOURCE: built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
Posted on Dec 19, 2009
I have a RCA TV Model L46WD22YX5 it will not read any channels with an antenna, HELP!
The whole USA (years ago now) converted to digital TV signal format from analog (which is what your TV uses), this means that the TV will not pick up any channels without a digital to analog converter box, you can buy them very cheap on eBay.
Nov 24, 2016 | RCA Televison & Video
Is my rca f27442 tv digital compatible?
Sorry no.All CRT(tube tvs) are analog tv.It all digital now,must have Digitial converter box and a roof or digital antena to get the analog tv to get the free DTV digital signal.Or u must cable tv.Only LCD tvs have the digital tuner insidide to pick up the free DTV digital signal without the converter box.
Sep 02, 2010 | RCA F27442 27" TV
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
How do I get it to channel 3 to use my converter box
turn on the converter box and then scan for channels on the tv. Channel 3 should be picked up by the tv as having a signal.
Mar 09, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Converter Box Problem
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
Oct 29, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
MITSUBISHI HC 100 PROJECTOR
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Jan 03, 2008 | Mitsubishi HC100U Multimedia Projector
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
