Question about Dryers
The dryer is leaving what looks like brown burn marks on clothes
I have a Whirlpool stacked washer and dryer, and the dryer keeps leaving little brown burn marks on the clothes. I've taken the dryer vent completely off the back and blown out the line, so it's not plugged as the clothes were not getting dryed well enough in one cycle, but the burn marks are still happening and getting worse I think.
  • goosegoss27 Apr 24, 2009
    No, the brown marks are about an inch long and about 1/4 of an inch wide, but they vary in size. I've seen them on white or light colored T-shirts and they could be anywhere from the middle of the shirt or really anywhere. The drum is just a white drum, no speckels. Thanks.
  • commissiondr May 11, 2010
    Would you be referring to small brown spots on the collar points of white mens dress shirts, or at the bottom of the front tails ? If so, check baffles on inside of drum for rough spots. Is the drum speckeled ? Blue and white porcelain?
  • 373 Answers
The marks are coming from your dryer seal. I had the brown mark problem on my Whirlpool LER4634EQ1 Dryer. It turns out that the inner drum seal wore the paint off the pilot diameter on the inner wall. The pilot diameter rusted and the rust transfered onto the seal. The marks on the clothes are rust marks. I replaced the seal on my dryer, but don't know how long it will last. You may need to try and paint the pilot diameter. The seal with glue was $34 delivered from pcappliancerepair.com. Here's pictures of the rust: http://s2.photobucket.com/albums/y48/ZeeVert/Whirlpool%20Dryer/
Posted on Jun 11, 2010
  • 113 Answers
You might need to replace the felt on the inside front that the tub rides on
Posted on Apr 24, 2009
My dryer is not drying the clothes all the way and it is leaving little brown marks on my white clothes.
sometimes lint can build up on the back side of the dryer drum and get burned then the dryer will dump the burnt lint in the drum . most dryers have a double element and when the one side goes it breaks in two and only puts out half the heat if you are mechanical take it apart good tip take pictures with a camera and white paper tape to label wires if attempting to take apart un plugg
Jan 14, 2010 | Whirlpool GEW9250 Electric Dryer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Clothes dryer brown marks problem
if that mark is comming from the dryer .the drum has a rust. and you cant paint it or the seal of the drum is bad that seal is around the drum.
Feb 18, 2008 | Whirlpool LTE6234D Top Load Stacked...
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Dryers Logo
1,514 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
