Question about Bosch Benvenuto B20 Espresso & Coffee Maker
Grinds but no coffe come to cup - Bosch Benvenuto B20 Espresso & Coffee Maker
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
Brew group/thermostat ?
Definitely sounds like an overheating issue. Especially if you have to wait a half hour for it to cool down and then it brews again. If it is under warranty I recommend replacing it.
Jan 24, 2014 | Saeco Vienna De Luxe Espresso Machine
I need the user manual
Dear friend: I bought mine in 1996 in Orlando. The user manual was so simple with some b/w pictures.
1.- Heat the water.
2.- Over one cup place the thin filter that match perfect and is the bigger one of two elements supplied.
3.- Over the thin filter place the coffe deposit the one that have small holes at the bottom.
4.- Fill the deposit it with coffe for one cup and fill over with hot water slowly from one cup trying not to overflow.
5.- Wait untill the water flows down and your cup of coffe is ready.
6.- For another cup repeat this procedure.
Is a bit long but you can enjoy a room coffe for two.
Its what my experience was. Excelent when you don't find where to boil a cup of water. Now mine machine burns suddenly the heater and I am trying to find the replacement part, but probably should be and adaptation of it.
Good luck. The manual is not much than what I told. Not much manufacturer info. A pitty for a well designed help machine.
Claudio.
Apr 03, 2013 | Franzus TJ-10 Coffee Maker
Just picked up a new Franzus TJ-10 Coffee Maker at a garage sale, but it has no instructions with it. Can you please tell me just how to operate it. Appreciatively, Vincent
1.- Heat the water.
Claudio.
Aug 07, 2011 | Franzus TJ-10 Coffee Maker
When i make a cup of coffee with my kuerig coffee maker my coffee is coming out with coffee grinds though it. how can i fix this problem?
Your coffe may be ground too finely for your maker.
Is your coffee maker flat-bottom or cone shaped? Or is it a french press?
Your coffee needs to be ground according to the brewing method. Too coarse and it will be watery, too fine and it will be too dark, or you might get grounds.
May 06, 2011 | Vacuums
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Bosch Benvenuto B20 Espresso & Coffee Maker Logo
41 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Andrew Taylor
Andrew Taylor
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
