Question about GPS
Hi, I am trying to connect my GPS to the cigratte lighter and its not charging it. I spoke to one of the mechanics and he told me that cigratte lighter connection is only used for cigrattes ligher you
Hi, I am trying to connect my GPS to the cigratte lighter and its not charging it. I spoke to one of the mechanics and he told me that cigratte lighter connection is only used for cigrattes ligher you can't plug ur GPS in to charge as it needs 12v. I am wondering that I got 2000 ford model how could that be possible. Could anyone please advice how to charge GPS in ford falcon then? Thanks. Regards, Joe
  • ultimatejawa Apr 24, 2009
    Yes that is true, it is hot when the car is running but that outlet is also use to recharge mobiles and GPS. I have a GPS which needs to be recharged and I have no option because it is not working for me. Could you advice in Ford Falcon 2000 AU is there any other outlets for 12v as now in new cars they have introduced new outlests with a cap on them showing its 12v outlet to recharge mobiles and GPS. But my ford doesnt seem to have one. Can anyone advice if they have ford falcon 2000 AU model and they have same problem or do they differntly like is there any other outlet.
    Please advice.
    thanks.
    Problem Solver:
  • 15 Answers
Remember, the lighter outlet is only hot when the vehicle is running. Few vehicles come with an aux outlet that is hot all the time. Trucks do but not cars.
Posted on Apr 24, 2009
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
Cigarette lighter socket came out, no charging
You probably pulled the wiring plug off the back of the socket. Or the fuse went when the socket came out.
Mar 05, 2014 | 2002 Toyota Camry
Fiat stilo 2002 1.2 which cigratte lighter use
unless you have something special cigarette lighters are the same. Check the removable section with another from somewhere else and if they are the same the you can get lighters fro good auto spares shops.
Nov 13, 2013 | 2002 Fiat Stilo
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Don't work with the cigarette lighter connector
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Aug 09, 2008 | Garmin 010-00358-00 GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
GPS does not get charged
hi try a different dc adaptor thay are cheap enoughg
May 28, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin gps 296
If it does not show 'charging' when connected to power, then something may be wrong with the power cord. If it is the vehicle cord (the one with the cigarette lighter plug) check the fuse in the tip of the cord.
May 10, 2008 | Garmin GPSMAP 295 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
116 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
