Question about SVA-USA VR-30W 30 in. LCD Television
I need a model:SSU-S0061(SSU-S0061-1B) I.T.E Power Supply For my tv to have power and work.
Hello, I come from Shenzhen, China, I have you need the power of this model(SSU-S0061-1B). Please contact me. MSN:ttxiangtao@hotmail.com
Posted on Sep 11, 2009
Techwood tv 42" model 42832 was working nipped to shops so pressed power button on side came back ten mins later switched it on and came on and changes diff colours as seen in video how can I fix this
you have a power supply partial failure if you know how to safely check your power supply check the voltages, swolen capacitors etc. leaking capicators are usually the problem. if you know nothing about power supplies do not look at the tv without the tv unplugged! better yet; have the supply repaired by a professional. a power supply can kill you!
Feb 05, 2013 | Televison & Video
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
Power will not stay on , on my magnavox tv model 32mf337b/27 unplugged like user manual suggested but didnt work even after 30 hrs saw on magnavox.com a few people have had same proble with this model mine...
Magnavox has issues with puffed caps on the power supply. This sounds like its a 32 inch lcd tv. I tried searching for a service manual for this and can't find one. If it is an lcd you need to look at the capacitors on the power supply. If they are puffed up, you will need to replace them with equal or slightly larger valued capacitors. The capacitor values are mfd and voltage printed on the capacitors themselves. You will need a soldering iron to replace them. Lay the tv, if it is an lcd, on a flat surface cushioned by a blanket. Make sure the surface is large enough to support the tv frame, as you don't want to cause damage to the panel. remove the back of the tv. There are numerous screws, and once the back is off, check the power supply pcb for puffed caps. This is the board with the power cord attached. I know in magnavox tv there is a cage covering the power supply, so remove any connectors because you will have to flip the cage housing the power supply to get to the caps. If you feel confident, give it a try. Let me know how it goes
Apr 03, 2011 | Televison & Video
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
Missing Power supply and remote
Hi! i hope this would help, most power supply for 20 inches lcd are rated 12volts dc at least 5ampere. try replacing your power supply.
Aug 28, 2009 | Polaroid FLM-2011 Television
Power supply model 090-02180-13 has stopped working. Dead...
look at the voltage and size of the plug that goes into the tv and you can get these pretty easy from the manufacter
Jul 02, 2009 | Televison & Video
Need new power supply for this tv
I like you last comment. LOL
All brand of TV are having somewhat the same problems.
I believe a law needs to pass to have the TVs last longer than 5 years. I see TVs all the time only lasting 16 months.
This web site has 2 complete power supplies in stock right now. Here's the link:
http://www.shopjimmy.com/catalogsearch/result/?q=TLA-04011C+power
Jun 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
the tv has one part of the power supply working this is needed to have the microcontroller ready to work. But the tv needs more than that for work im talking 'bout the high voltage power supply who is now damaged. the parts required depends on the diagnosis in the bench but at least two are needed. the cost of this repair of course depends in how many parts are going to be replaced, but i concider this repair kind of average in this technology.
Apr 13, 2009 | RCA 32V524T TV
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Berndulay@yahoo.com
Accroding to your model number:(KV-...) In sony tv units power supply porblems is very low unless a power surge.
You have to check these things.
1. Stand by 5V available or not
2.If stand by 5V available press power and check B+ is getting or not
3.If B+ available check Horzontal oscillation
4.May be H-out transistor or video amplifier is bad.
Oct 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
SVA-USA VR-30W 30 in. LCD Television Logo
810 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
