Question about Aerogrow AeroGarden
Pump wont work - Aerogrow AeroGarden
My fuel pump wont work
fuse, relay, ignition switch or the pump itself
Aug 11, 2012 | Pontiac Firebird Cars & Trucks
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Fuel pump wont stay on wont start replace the
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
Nov 10, 2009 | 1983 Dodge Pickup
1997 blazer fuel pump problem.....
ya the fuel pump wont pump with the lines off but the pump is going bad they will work and wont work
Mar 06, 2009 | 1997 Chevrolet Blazer
2001 kia rio fuel pump does not work
Are you positive its the fuel pump? Have you tried running the pump with the return line off to see if it pumps fuel? They don't always have to make a noise.
Also refer to www.kiatech.info
Jan 10, 2009 | 2001 Kia Rio
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Aerogrow AeroGarden Logo
106 people viewed this question
Top Aerogrow Garden Experts
Dennis Key
Dennis Key
john h
Are you an Aerogrow Garden Expert? Answer questions, earn points and help others
