Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Panasonic 53" HDTV rear projection tv Blue on screen
My tv has a blue arch that goes across the bottom of the screen, it makes any kind of writing look double. I tried to adjust the converge, but it didnt help. Any suggestions?
  • Anonymous Nov 27, 2007
    i have a 47inch rear pro. 720p same thing after 4 years yellow green blue lines around images
"But I still highly recommend not using an xbox on these big screen tv's since it will shorten the lifespan of the video chips by 50%!" Care to cite a source for this claim? Sounds like fishy hearsay to me. In any event, yes you will definitely need to make a service call to get this repaired. I'm having the same issue right now with mine and not long ago I had a capacitor go bad (which also required a $400 house call). Though I don't have the links anymore, a google search found me a few do-it-yourself forums that had some anecdotal instructions on how to replace the parts yourself. From what I read, in most cases these parts are under $50, but don't quote me on that.
Posted on Oct 07, 2007
I had the same issue. Basically, it's a convergence problem. The video chips overheat. And believe it or not this will happen every 4 or 5 years. I paid $400 to fix my Panasonic big screen tv. To top it off, I believe it was my xbox that did it - well, maybe it just pushed it over the edge since I've also had my tv for 4 years. But I still highly recommend not using an xbox on these big screen tv's since it will shorten the lifespan of the video chips by 50%! Rich
Posted on Sep 29, 2007
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
My screen has a blue rainbow across it that pulls picture upwards projection tv 1080i
Replace Both of your STKs convergence ICs they are big black ICs.will have part numbers on them.
Jun 09, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blue line across panasonic large screen hdtv
What is the model number of your set?
Dec 30, 2007 | Televison & Video
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
