Question about Music
When I load a floppy disc in my Korg i5m, it keeps saying (error unable to load disc). It used to be 'OK' but started this problem just recently ....any help appreciated.
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a old (but almost unused) Korg d1200
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Posted on Jun 18, 2011
Korg d3200. I can't play or burn cds all of a sudden. Says no disc after inserting a disc. What up?
It sounds like the drive isn't working correctly. i suggest taking it to a Korg authourized repair shop to get it looked after as they will have better access to the needed parts. You can find one in your area through this link-
http://www.korgusa.com/KorgDealers
Mar 01, 2016 | Korg Music
I need to factory reset my X3
update it or flash with new latest files
Mar 21, 2015 | Music
Factory reset on korg x 50
FACTORY RESET:
  1. Press the [GLOBAL] button to enter Global mode.
  2. Press the [EXIT] button.
  3. Press the [UTILITY] button
  4. Select "Load Preload Data," by using the ClickPoint [?] button, and press the [CENTER].
  5. Choose "Kind," (All)
  6. Press the [MENU/OK] button.
  7. When a dialog box will ask you, press the [MENU/OK] button
May 01, 2014 | Korg X50 X-50 Keyboard
Unformat floppy disk emulator
Your questions,what does it mean?
If you use PA50SD,of course you don't need floppy emulator.
If you use PA50 with floppy emulator,you need to format the flashdisk with special softwares (SFD 1.23 etc) that usually included when you buy the emulator.
Jan 19, 2014 | Korg Pa50 Professional Arranger Keyboard...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
Unable to format sd card. Keeps saying protected when it's not.
1) Check to make sure the SD card itself does not have the protect switch in Locked position. There is a physical locator as you had with floppy disks to prevent erasure.
If they are not locked, the tab switch that contacts the tab when it is not locked may be dirty, bent or broken. A visual check in the slot can tell you if there is damage.
Mar 29, 2012 | Korg Kaossilator Pro Tabletop Synthesizer
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
Jun 17, 2011 | Korg D888 8 Track Recorder
My korg o1wfd needs a new floopy drive,but I don't know which one
This I am afraid is going to be a real problem. The original 01WFD's were shipped with the single density (720Kb) floppy drives, not the easier to find 1.44Mb ones. You could try contacting Korg.
From experience I can tell you that while many of the drives have similar interfaces, the music companies often had drives that required special strapping in regards to the drive select. There are not many of the single density ones around anymore... you might find one in a computer recycler's archives.
Trying to use the common double density 1.44Mb disks in the Korg is NOT going to work either, and if you have tried this, that MAY be why you are having problems, and new floppy drive isn't going to fix the problem... The "artifacts" left by 1,44 formatting remain between the tracks when put into the Korg.
To get around this, you can try TAPING over the extra hole that 1.44 disks have AND most importantly magnetically DEGAUSS the disk and then reformat using the drive in the Korg.
Feb 03, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from korg.com. You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
Music Logo
26 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
