Question about Intake Manifolds
Passat b6 withmil P1027 - Intake Manifolds
How do i remove the gear knob and gaitor from a vw passat b6 2009
Hi. you pull the trim up at the leather insert.Disconnect the wire. Lift the black plastic shaft lock, pull the silcver button out and while holding the button out pull the lever up. It can be quite hard.
Jul 13, 2014 | 2009 Volkswagen Passat 1.8
Where is the valve on a 2005 vw passat. B6
Please give more info. there are a few different valves.
Oct 19, 2013 | 2005 Volkswagen Passat
Are all the parts on audi a4 b6 the same as Volkswagen passat etc?
No, Other than the frame of the car, and in some models the engine, most of the parts are different.
Mar 31, 2013 | 2002 Audi A4
Need fuse box diagram for 2006 volkswagen passat
On this website (link below) you find fuse box diagram and description for Volkswagen Passat B6
http://www.autogenius.info/en/volkswagen-passat-b6-fuse-box-diagram
Jun 26, 2012 | 2006 Volkswagen Passat
I get two ECM Codes P0035 and P1027. The car idles rough and stalls when you start it.
P0035 - Turbo Charger Bypass Valve Control Circuit High
Can't find P1027 anywhere.  Sorry!
May 17, 2009 | 1998 Volvo S70
Intake Manifolds Logo
46 people viewed this question
Top CFM+ Plus Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CFM+ Plus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
