Question about HP 190 Copier
"Scanner failure" message
When we power up this message appears on the screen with the suggestion to turn off and on again. Cycle repeats as long as you're willing to try it! My first guess is that the scanner lamp is out - either lamp ot HV supply. HP no longer services these directly and I am unable to find local central Maryland) service. If I can find documentation I amy be able to service it myself. Any suggestions?
  • 1 more comment
  • davepfz Sep 26, 2007
    I am not sure what you mean by the 'variables'. I disassembled the unit down to where I had the scanner module out. Then reassembled and now the unit works! It is probably a poor connection somewhere. I have located a source for refurbished units and am considering purchasing one to have it on hand.
  • candi_brooks Jun 25, 2008
    "Scanner Failure" massage appears. I took the top of and took the scanner module out and put it all back together again and the same message appears. What should I do?
  • Danny_18 Mar 04, 2009
    "Scanner Failure" message appears.. And HP says they no longer service "DINOSAURS".. what a piece of **** this thing is!!!!!!!!!!!!!
  • 163 Answers
Pleaz adjust the variables of scanner unit if no set then change complete unit ,i have also face this problem some times
Posted on Sep 26, 2007
SOURCE:
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Monitor has no picture, repeatedly tries to cycle ON but can't
sounds like power board failure. You can disconect power lead for 30 minutes and try again but it does sound like end of life
Feb 04, 2018 | NEC Mitsubishi Diamond Pro 2040u NF...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure during the initalization/starts up.
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Oct 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner will not move when turned on It will move if i force it.
If the scanner Fails it will give this message, Try the steps bellow to check if it can be cleared.
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Sep 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 190 Copier Logo
212 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
