Question about Kenwood Unity System
Can kenwood ge970 be used with any amplifier?
The kenwood ge970 hase input and output connectors so I thought that it could be used with any amp with preoutpowin connectors. But, someone told me it will only work with the A97 amp. Is this true?
Can anyone let me have a manual for this?
    Sergeant:
  • 183 Answers
You need to go to the electronics store where you can buy them, Ask the guys or gals there, what's up. No one on here can tell you that.
Posted on Apr 24, 2009
Can i bridge an ev1500m ssl amp to a kenwood kac-8104d amp
If I understand correctly you want to bridge one amp and the power output into the other. If so no it can't be done like that. It would damage the input of the other amps input as well output of the other
Jul 09, 2016 | Kenwood Car Audio & Video
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
My amp gets really hot as soon as the power comes on. what does that mean
Check your speaker output cable and connector, they might have connected to body of car.
  1. Remove all input / output cable from amp
  2. Plug the power into amp.
  3. if still the amp is still heating.
  4. Check if any screw used to fix is not connected any part of the amp output or input point.
Jul 22, 2009 | Kenwood KAC-728S Car Audio Amplifier
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood 350 w-2 amp wiring
you can simply take the input and connect it in parallel to the input of the second amplifier. The output of one amp will go to one speaker, and the output of the other amp will go to the other speaker.
The inputs of amplifiers are "high impedance" so putting more than one in parallel won't put any strain on the radio circuit.
Hope this helps.
Mar 27, 2008 | Kenwood KAC-5203 Car Audio Amplifier
My amp turn on but for some reason it dosent push out any power to the sub
Make sure there is not an input level control and that you have the right RCA connectors from the head unit connected. If you do see an input control first see from the head unit specs on what the max. output is comming out from the head units VIA the RCA Plugs. then see from the amp specs what the max. input should be inputted to the amp . If the output from the head unit is higher then the allowed input from the amp, your going to blow up the amp the first time you crank it. I have seen this happen many times. if you do not know how to balace the input of the amp please read the instructions on the amp or seek a professionals assistance.
Oct 09, 2006 | Kenwood KAC- X810D Car Audio Amplifier
Kenwood Unity System Logo
569 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
