Question about Oster 4724 Rice Cooker
Doest work it says E2 error? didn't work - Oster 4724 Rice Cooker
  • 2,113 Answers
Try replacing the thermal cutoff
http://myplasticfreelife.com/2011/07/how-i-fixed-my-broken-rice-cooker-the-complete-illustrated-instructions/
Posted on Oct 18, 2013
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
Singer stylist E2 error code bobbin winding
I have just repaired a 7258 with a frozen bearing unrelated to the E2 code except that I thought I would lube the entire machine while it was apart, and through my ignorance, I greased the clutch that releases the mainshaft when winding the bobbin, and then when the clutch wasn't working correctly, caused the E2 error. I can say the E2 error is not caused by a plug not seated correctly, too much tension in the bobbin thread, or God having a bad day. The E2 error code is thrown when the bobbin holder is in the wind position, and the mainshaft rotates. There is a clutch just behind the hand knob on the right side of the machine, and if it has too much lubrication with a stiff grease, or on an older machine, if the lube has dried out, the clutch will not release properly. I took the clutch apart, cleaned the grease I put in it, and then lubed it with bicycle silicone oil. It now works as designed. The hardest part of the repair was figuring out how the plastic cases split apart! If anyone in the SF Bay Area has a 7256, or 7258 that gives the E2 code, I can fix it - it's actually kind 'a fun...
Feb 08, 2013 | Singer Sewing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
Apr 15, 2011 | Haier Dehumidifiers
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
Error codes
Does it show ERROR 2, or just E2?
E2 isn't actually an error. It just shows that the unit is set to SCART 2 input.
Mar 13, 2008 | Philips DVD750VR DVD Player/VCR
Oster 4724 Rice Cooker Logo
447 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
