Question about Soyo SKT 478 865PE (SY-P4I-865PE) Motherboard
SY-865PE Dragon3 Fire
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram Ican run with a 865pe neo2-p motherboard and
Main Memory
�� Supports bandwidth up to 3.2 GB/s (DDR 400) for single-channel mode and 6.
4GB/s (DDR 400) for dual-channel mode (for 865PE only).
�� Supports two (for 848P) / three (for 865PE) unbuffered DIMM of 2.5 Volt DDR
SDRAM
�� Supports up to 2GB (for 848P) / 3GB (for 865PE) memory size without ECC.
�� Supports only x8, x16 DDR devices.
�� Supports Dual-channel (for 865PE only) DDR 266/333/400 (based on DIMM 1.3).
(For the updated supporting memory modules, please visit http://www.msi.com.tw/
program/products/mainboard/mbd/pro_mbd_trp_list.php.)
Regards.
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
What is the max ram that I can install in the 865pe neo2-p board
The MSI 865pe motherboard can use up to a maximum of 4GB of PC1600/2100/2700/3200 non-ECC DDR RAM
SY-8BA+IV Manual
go to soyo web download free jim
Mar 19, 2010 | Soyo Motherboard...
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Soyo SY-P4VDA Motherboard Problem
best thing to do is disconnect floppy, take all other board/pc card out of the computer remove cdrom, now you just have a hard drive
turn it on see where it goes. if it doesnt work try a different hard drive or just the cdrom but make sure you have boot from cdrom on in your bios.
Dec 14, 2007 | Soyo SY-P4VDA Motherboard
Soyo SKT 478 865PE (SY-P4I-865PE) Motherboard Logo
42 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
