Question about Miller Trailblazer 251 Generator Welder
Welder engine runs bt will no produce power to welding terminals
My welder revs up but wont put out full power
We need a better description of what is happening. I see many engine driven welders that when loaded up heavily the engine rpm drops because of needing a tune up or complete engine overhaul. Since the engine can't run at designed r.p.m. the welder won't put out "full power" With a better description of problem, Such as engine is not slowing down but will only weld at 100 amps experts here could help you better.
Sep 18, 2014 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Restore magnetic field to welder generator?
Look on Youtube for videos on how to flash the field.
Sep 15, 2014 | Lincoln Ranger 225 Engine Driven Welder...
My welder no longer produces high quality welds
You could have a poor ground clamp connection. Check that. also increasing the gas flow will cause turbulence at the weld, this can have a negative effect on weld quality.
Check your connections, check your liner, actually, replace it if you haven't recently.
Feb 15, 2010 | Lincoln Electric LE 83180 Century...
NO arc or power on my Welder/Generator
check your back panel fuss and brakers
Oct 11, 2009 | Welding Tools
No welder output
Sounds like a control board problem, would much more info to diagnose.
May 29, 2009 | Lincoln Welding Tools
No output from my lincoln ac welder/generator
Check excitor coils, they produce power from the generator head..
Apr 02, 2009 | Welding Tools
My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Mar 17, 2009 | Welding Tools
Lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Feb 23, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Jan 23, 2009 | Welding Tools
My welding machine will not weld?
Hi, put the setting on 150 amps, and see if the welder welds. do you have a gas or electric welder?
some welders have a reset botton in front. tell me how many amps your welder produces.
If this doesn’t work for you please write back. Thanks,
Nov 22, 2008 | Welding Tools
Miller Trailblazer 251 Generator Welder Logo
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
janman
Lawrence Oravetz
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
