Question about Frigidaire GLGR331A Gas Dryer
Dryer making clicking sound, humming and vibrating hard
My dryer started off not drying the clothes, we cleaned out the lint (from the back coil, the aluminum pipe in the wall and the lint trap area). That fixed that problem. That was the only problem our dryer was having, that is until we cleaned it. NOW, the dryer has been humming loudly and vibrating alot, but it is tumbling and drying the clothes. I have used it a couple of times. NOW, the dryer is also making an on and off clicking sound. It appears that it is not generating heat. I just opened the dryer and the clothes are cold, no heat and it smells like gas. What is going on? How can I fix this? PLEASE HELP!!!
  • 3 more comments
  • Chigal74 Apr 24, 2009
    To clarify the problem, the dryer was not heating so we moved it out and cleaned the lint from the lint trap area, removed the aluminum coil and cleaned all that and where it connects to the wall. When we put the dryer back, it began to rattle (vibrate) alot and making a humming sound, but it was drying the clothes. I used the dryer a couple of times since that today. The last load I put into the dryer, the dryer began not only doing the previous, but now started making a continuous on off clicking noise. The glow came on momentarily, but then nothing (no heat produced) just clicking. I opened the door to the dryer and it smelled like gas. I hope that helps to clarify (this all happened today). Curious, how do I check for the leveling position issue?
    Thanks for your reply. To clarify the problem, the dryer was not heating so we moved it out and cleaned the lint from the lint trap area, removed the aluminum coil and cleaned all that and where it connects to the wall. When we put the dryer back, it began to rattle (vibrate) alot and making a humming sound, but it was drying the clothes. I used the dryer a couple of times since that today. The last load I put into the dryer, the dryer began not only doing the previous, but now started making a continuous on off clicking noise. The glow came on momentarily, but then nothing (no heat produced) just clicking. I opened the door to the dryer and it smelled like gas. I hope that helps to clarify (this all happened today). Curious, how do I check for the leveling position issue?
  • Chigal74 Apr 25, 2009
    Thank you for all of your help. However, I was able to figure it all out on my own. It had nothing to do with the suggestions listed above. In fact, the vibrations were due to extreme lint jammed into the blower/fan. I didn't know about this, until I took off the top and front of the dryer. I got the idea from a different post on here (where they found credit card jammed in there). It appeared that when I was cleaning the lint trap area with the lint brush, I must have pushed down and jammed additional lint into the blower. The reason for the no heat is because of all the vibrating and a sensor tripping that shut the gas off to prevent fire. Thank you again for your help.
  • commissiondr May 11, 2010
    See if you can adjust the ignitor somehow to be closer to the burner assembly. If you touch the ignitor, use gloves to keep the oil from your hands off the ignitor surface. Is there a flame sensor next to the ignitor somewhere? (may look like a little stick with a little wire attached ? If so, use some fine sandpaper to roughen the little stick. And, make sure there is no lint around the burner assembly. If you smell gas, it may not be coming all the way down towards the path of the ignitor, and that would cause no heat.
    Regarding the leveling issue, use a standard level, set it in the middle of the dryer and make sure the bubble is in the middle. Then you can adjust your dryers legs up or down, by screwing them in or out.
    Frigidaire had some notorious trouble for bad drum bearings, or rollers on the rear of the drum. Check leveling position since you moved it. If it over heated due to heavy lint build up, thermal limit switches kicked in to avoid a fire hazard. If this unit is 5-10 years old, you may need an ignitor. They become brittle over the years, and that little moving to clean the vent may have done the trick. If the ignitor glows, tap the gas valve lightly with a wrench or something. Sometimes the plunger inside the gas valve on the dryer will stick. The clicking is probably the valve, and ignitor is bad.
  • Frigidaire Master
  • 8,220 Answers
Check this out:
55b4358.jpgAs you can see they ain't very hard to replace. It is not necessary to remove the gas assembly to replace these. You can get em fer $15 here
More repair photos HERE
Posted on Jun 17, 2010
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
DryerDryer making clicking sound, humming and vibrating - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Posted on Jun 15, 2010
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
How stop front loading electric dryer vibration while drum is rotating clothes.
110 means you have a whirlpool dryer. If the filter is on top then I would say you have a bad glide, if the filter is in the door you have a bad wheel, very rare. At any rate you need to open it up and inspect it.
Videos and more on kenmore dryers
Mar 06, 2012 | Kenmore Dryers
I have a kenmore gas dryer model 110.74894401. When the start button is pressed it sometimes makes a clicking sound and the dryer does not start. However, when the dryer does start it tumbles for 15-20...
how old is the dryer?sounds like the motor is bad.i see this when the owner doesn't clean out the dryer,it's not that hard to change out the motor,if it's in good shape and not to old go for it but you gotta clean the dryer out,you need to clean out the duct that the lint filter slides into,if you have a shop vac blow off all the lint on the motor and out of the heating box or tube and vac out all the lint and if the vent line is long remove it from the back of the dryer,go outside and make sure the outside vent is clear and then from the back of the dryer blow out the vent line with a leaf blower,i've seen bird nests blow out of the vent lines,you could have a fire in the dryer or the dryer will run hot and damage parts and your clothes will take a long time to dry.all a dryer does is move air,if it can't your gonna have problems,let me know what you find and how you make out,if i can help you with anything else let me know
Aug 29, 2010 | Kenmore Dryers
My dryer makes my clothes stink
You NEED to have a professional vent company clean your dryer out! PLEASE don't run your dryer when you're alseep or not at home due to a fire hazard! It sounds like the dryer is full of lint that's buring and make sure you clean your lint filter EVERY time you dry a load for safety's sake and energy efficiency.
Aug 14, 2009 | Dryers
Dryer vibrating alot and making alot of noise.
check the felt around the inside of the door to see if it needs to be replaced
Apr 23, 2009 | Dryers
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer heats up & spins,clothes don't dry,lint areas are now clean
restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Jun 05, 2008 | Roper REX5635E Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Frigidaire GLGR331A Gas Dryer Logo
1,533 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
