Question about Samsung SC-148 CD-ROM Drive
My samsung cd-rom sc-148c on a dell pc does not open anymore. The indicaterlight does not work too. What to do?
    President:
  • 1,179 Answers
It sounds as if either the power cable on the back of the drive has come loose, check first before going further, if that is still connected then the most likely scenario is that the drive died. You can pick up cd or dvd burner at any computer store for around $30 max. Hope this helps.
Posted on Apr 23, 2009
Re: Samsung CD-Rom SC-148C in Dell Dimension 2350 Cannot eject/open tray to CD-Rom - I have tried ejecting tray while re-booting from setup to see if its a software problem of some kind. I've...
  1. Turn off the power to the computer.
  2. Insert a steel rod (about 1.3 mm in diameter) into the emergency eject hole and push hard. (A stiff paper clip may be used).
  3. The disc tray is ejected a short distance. Pull it all the way open by hand. roadfox_2.jpg
Jun 01, 2011 | Samsung SC-148 CD-ROM Drive
Will a samsung sc 140 in a dell inspiron 531
Hi Grannyking - Sorry, the answer is no. Your PC only has connectors for drives using the current standard SATA connectors. The Samsung SC140 uses the old IDE standard for connections so there is nowhere to connect the Samsung,
Regards, Mikeyaf
Mar 06, 2011 | Samsung SC 140 (SC-140) Internal 40x...
Cd rom doesn't operate some cds although they works on other one it's type is samsung sc-140b
For about $40, replace your _OLD_ CD-ROM drive with a new CD/DVD reader/writer, which will be compatible with _any_ disk that you feed it.
Jul 20, 2010 | Samsung (SC-140B) Internal 40x CD-ROM...
I havent sc148 driver
you can download it in the following websites.
support.dell.com/support/.../type.aspx?c...SC...
dell.driversdown.com › dell Servers drivers
Dec 19, 2009 | Samsung SC-148 CD-ROM Drive
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
My samsung cd rom sc 148c is not working i am getting this message under properities Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) i have...
If it's not a SATA drive try to set your IDE Controller in Device Manager to use DMA mode not the PIO. If it won't help try to find updated firmware for your drive and install it. Read Carefully Installation Manual Before! If it won't help that's a sign that your PC wants you to upgrade it with DVD/RW instead.
Good Luck!
Apr 17, 2009 | Samsung SC-148 CD-ROM Drive
Have a Dell 667Mhz 64mbit ram pc w/windows 98 on
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Mar 29, 2009 | Samsung SC-148 CD-ROM Drive
SAMSUNG CD-ROM SH 152>> Detection Error
Dear Sheila
After connecting it to the motherboard, switch on the pc, then go to properties of "my computer" then choose "Hardware" then choose device manager and over here u will come to know weather ur CD rom has been detected or not, if it has a question mark then it means u have to install drivers for it, but if ur using Win XP, i am sure it shd detect automatically and need not ask for drivers. Hoping a good rating from u....!!!
Thankyou
Feb 15, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Samsung SC-148 CD-ROM Drive Logo
732 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
