Maytag agitator removal
Remove agitator for maytag a510
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
jsrock516
  • 5911 Answers
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
SOURCE: maytag washing machine
Just to clarify weingpc's response, if you pop off the cap and look in, you will see a 1/2" square socket. Take your 1/2" extension and rachet, drop it in and unscrew it counter clockwise. Pull it out and pull out the next piece underneath, which if you're having problems with the agitator being "jumpy" is the piece you need to replace.
Posted on Dec 20, 2008
SOURCE: Need to remove agitator as material jammed underneath
remove agitator as material iammed
Posted on Apr 14, 2010
How to remove the agitator from a Maytag Washer PAVT-1 in order to untangle caught cords
Open the lid, remove the Fabric dispenser, then you will see a nut in the agitator, remove it and lift the agitator out.
Nov 20, 2010 | Maytag Performa PAV2200
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
How do i remove the agitator
If this is a true Maytag, there is a 1/4 inch hex head bolt in the lower portion of the agitator, on the side. Loosen the bolt and pull the agitator off. If not a true Maytag I will need a model number.
Jul 05, 2009 | Maytag Washing Machines
Scarf stuck around agitator.
remove cap and ,,remove 1/2 inch agitator screw and pull straight up
Aug 15, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Seal leaking from tub. How do I remove agitator?
Aug 11, 2008 | Maytag Washing Machines
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Nov 28, 2007 | Washing Machines
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
