Samsung ah64 aux not working
Thanx for this site. What is the part number for my samsung home entertainment system ah64-05236b? ... the power supply part, I have Googled, but cannot find the right part number for power supply
I would be difficult to find power supply of home theater systems online. you have to consult the service center.
If you wish to get some details then check the following link
http://electro-medical.blogspot.com/
Jul 29, 2016 | Samsung Televison & Video
Ah64-04904a
Setup procedure is too much to type in here, and is not practical. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 30, 2014 | Samsung AH5902131F Remote Control
Samsung ah64-04467f
3of my speakers are not working when i change the it to different sockets its work ,so can u tell me wats the problem is plz
Dec 28, 2013 | Audio Players & Recorders
Samsung AH64-04467E Home Theatre powers on but then goes to Protect and shuts down
Start by disconnecting all of the speaker wires usually direct short causes protect to shut down.
Are the speakers the right ohms
Sep 28, 2011 | Audio Players & Recorders
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Feb 11, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Samsung code for a comcast cable box
The Remote w/ On Demand buttons, it's the same as the DVD player code 1932. Hit the AUX button, press and hold SETUP until AUX blinks and enter 1932. Press the power button and it should turn off the reciever.
*UNLOCKING VOLUME CONTROL* You must until your AUX volume control in order to use your Comcast remote. To do so, you must select AUX, press and hold SETUP until AUX blinks. Enter 9-9-3 and press Vol - (down). This should unlock your volume control when you select AUX. I'm not sure how to set AUX as your default setting for volume, unless you were to program your AUX device as your TV and vice versa I'd suspect.
Hope this helps!
Sep 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
27 people viewed this question
 Grubhead
Grubhead
