Question about Photography
I've finally used all my film but I can't find the rewind knob, help!!
  • kakima May 10, 2014
    Can you find the make and model of your camera?
2 Suggested Answers
SOURCE: loading film
there's a tiny black button to the side, beneath the rewind lever, press that as you pull up on the rewind lever
Posted on Jan 28, 2008
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
I did by a canon a-1 that been alredy used the problem is that there is no rewind knob upwards so i can open the back of the camera help please
You'll need to find a shop and hope they've got a knob in their parts bin that they can install for you, as that'll be your only option. Without it, not only will you have no way to open the camera to load/unload film, but you'd also have no way to rewind it once you shot it.
Sep 04, 2011 | Canon AT-1 35mm Film Camera
Cant wind up film!?
You haven't stated whether you activated the rewind knob before trying to rewind the film. Unless you do so, the rewind crank will not work.
The rewind knob is to the left of the lens mount (as viewed from the front of the camera), above the self timer lever and is marked with a letter "R". Turn it until the bar is horizontal and you should then be able to rewind.
if this has fixed your problem then please take a moment to rate my answer. If it has not done so, then please add a comment instead and I'll come back with additional options for you when I'm next online.
Jul 20, 2010 | Olympus Om1 Om1 Service Parts User Manuals...
My Canon EAS Film Rewind Knob is rolling my new film back into the cassette instead of into the camera...please help.
That's what the rewind knob is all about: It will allow you to rewind the film back into the cassette to avoid it to be exposed to the light and therefore losing your pictures.
When loading the film you must insert the film into the receiving spool by hand while the camera back is open. Make sure to advance the start enough so that the spool will 'stick' to the film.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
Can't open vivitar 5388
Use the rewind knob to rewind the film. Once the film is rewound, lift the knob up and the back should open. Then you can remove the film cassette and insert a new cassette and load the film.
Jun 11, 2009 | Photography
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Photography Logo
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
