Question about Holmes HAP1702-TU Allergen Air Purifier - Black
Aqs light not turning on - Holmes HAP1702-TU Allergen Air Purifier - Black
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
The pre-filter light is on when I turn it on
First, Turn off the unit. Thern, Rermove the pre-filter & gently clean with soap & water, rinse well. Finally, dry & replace back into unit. Then turn back on unit & the light should be off.
Nov 04, 2013 | Honeywell 52500 HEPA AIR CLEANER
Light blinks on and off.inside light turned off.
Clean metal fins and make sure there is no moisture on metal fins....let it air dry after using towels to remove all moisture on fins, then replace into body of ionic breeze.
Nov 10, 2011 | Sharper Image Ionic Breeze GP SI730 Air...
Honeywell HHT-011 Air Purifier red light will not turn off even after cleaning the filter three times.
For those who's red light will not turn off after cleaning. There is a little button by the red light indicator. Take a paper clip and hold in for about 5 seconds. Light will then turn off.
Jan 22, 2011 | Honeywell HHT-011 Air Purifier
I have 2 ionic breeze air purifiers sharper image.(germical )
I have the same problem as gerardperez7. One of my germicidal light quadras won't turn the light on and doesn't appear to be cleaning the air at all. I even put a new light bulb in it and it doesn't fix the problem.
Dec 19, 2009 | Sharper Image Professional Plus Ionic...
Holmes HAP1702-TU Allergen Air Purifier - Black Logo
Top Holmes Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Holmes Air Purifier Expert? Answer questions, earn points and help others
