Question about Toshiba Satellite M45-S169 Notebook
No power at all to laptop
Hello, I have a Toshiba Satellite M45-S331 laptop which is a few years old. One day I was listening to music and went to touch the mouse pad, and the whole thing just died. No power when it is plugged in, no lights come on, no lights when only on battery power. I removed the hard drive and attached it to another computer and all my data is still there. Is this a motherboard problem or did I short circuit something? Any advice on how it happened, and how I can fix it would be greatly appreciated! Thank you in Advance, Damian
M45-s331 I was replacing the wireless card and I broke one of the terminals that snaps to the card. Where can I either get the terminal or the little harness?
this will be the best link for this part:
http://www.ebay.com/sch/i.html?_nkw=Toshiba+Satellite+M45-S331+wireless&_sacat=0&_odkw=Toshiba+Satellite+M45-S331&_osacat=0&_trksid=p3286.c0.m270.l1313
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 10, 2011 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45 S331 Use to power all the time.When we went to install old hard drive to load Windows Xp.It went to screen to start set,then it shut Down.It will Not Power up,Why?
remove eh hard disk and see if the laptop boots up at least to bios settings ..If it does ..I suggest to reinstall the computer but first go to bios and change the ahci mode for hdd into ide compatible or native ..and save changes..This will eliminate the need for 3rd party drivers and will install proper..
No matter what you have on the disk ..it can not do this right the way ...It need s the operation system in order to work and make damages..and if you wipe it out it will not be there anymore. (in case of a virus) ..
I suggest to use a disk to install and not the old recovery ..
let me know how it works and what it does..and I will further advice in this matter
Aug 08, 2010 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
When I turn the computer on the screen doesn't work
This is the monitor not being attached to the Graphics Card properly.
Sep 14, 2009 | Toshiba Satellite M45-S331 Notebook
2nd RAM slot for Toshiba Satellite M45-S331
if its not under the laptop, it can only be under the keyboard.
Jun 18, 2009 | Toshiba Satellite M45-S331 Notebook
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
I dont find sound drive for this mdel
hi
go to this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1, click Download
2, select laptops
3, select satellite
4, just scrol down you will fine M45-S331
5, and select go
6, select operating system
and download
have a nice day...
Jun 02, 2009 | Toshiba Satellite M45-S331 Notebook
I went from XP Home Edition to Vista Ultimate.
You need to go to the Toshiba website for your location at this location: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# and select "Download" then type "M45-S331" into the search box. I would suggest you download all the drivers for Vista and install them. Good fortune to you.
May 30, 2009 | Toshiba Satellite M45-S351 Notebook
Toshiba M45 S331 power issue
Try this, remove the power supply and battery. Let it sit for about 15 minutes then re install the battery and power supply.
Oct 06, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S169 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
