Question about The North Face Apex Bionic Jacket - Women's
Patch hole - The North Face Apex Bionic Jacket - Women's
Tip
Minor Drywall Repairs
<span>It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.<br /><br />For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.<br /><br />The easiest way to repair a larger hole in wall board:<br />1. Cut a piece of new wall board larger than the hole you want to repair.<br />2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.<br />3. Using a drywall saw, cut out the outline of the patch on the wall.<br />4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".<br />5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.<br />5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.<br />5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.<br />6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.<br />7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.<br />8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.<br />9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.<br />Hope that this was helpful.<br />Best regards, --W/D--</span>
on Feb 03, 2011 | Plumbing
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Repair hole
i use cheap contact cement (dollar store tube works fine) and a bike tire inner tube (much better than crummy patch the give you) and apply some glue around hole and on bottom of patch, apply it smoothly, and aplly glue around edges (seams ) of patch. let dry for 2 days, if your using the transparent patch its like a sticker peel and smooth it on and let it dry for 2 days( in my opinion and experience they ****)
Mar 18, 2012 | Sevylor 2 Person Sit On Top Kayak
What can I use to repair a small hole in my coleman air mattress?
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
Sep 14, 2011 | Garden
I have Simmons deep sleep air bed which got 2-3 leaks :( Suggest me something..what to do next?
If the holes are small, a dab of rubber cement on the holes may be sufficient to seal them. Larger holes will require a patch of the same or similar material as the mattress itself.
To properly adhere a patch, roughen up the mating surfaces of the mattress and the patch. Sandpaper is ideal. Be sure the mating surfaces are clean and free of dust. Apply rubber cement to the patch and apply it over the hold. Apply pressure to the patch using weights (a stack of books work great). Let the repair sit this way for the duration of the time required for the cement to set up according to the instructions on the cement.
Hope this helps.
Regards,
DIYpro
Apr 27, 2011 | Sport & Outdoor - Others
Fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
Feb 03, 2011 | Washing Machines
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
What is the best way to patch a small hole in a towable tube
Your local sporting goods store should carry a patch repair kit that should work perfectly.
Sep 09, 2009 | 3M SportsStuff Speedzone 3 Inflatable...
Putting a hole in a sports patch
You need a leather hole punch. It's much like a paper hole punch, but with a different cutter. You can find them at craft stores.
May 04, 2009 | Bernina 1008
The North Face Apex Bionic Jacket - Women's Logo
16 people viewed this question
Top The North Face Sport & Outdoor - Others Experts
Bill Eager
Are you a The North Face Sport and Outdoor - Other Expert? Answer questions, earn points and help others
