Question about Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System
I have a Sta-Rite pool filter. In the start up procedure, you are supposed to bleed the air until a steady stream of water flows from the air release valve. Although I have confirmed that everything is installed correctly, I cannot get a stream of water to flow from the air release value and the pressure gauge remains at zero.
    Problem Solver:
  • 11 Answers
First make sure water level is right, try leaving air valve closed and see if pressure bilds, then open slowly you should get a stream.
Posted on Apr 24, 2009
    New Friend:
  • 77 Answers
Hi sstanl, Is your pump output or flow normal back to pool? if there is no water flowing through system you will get no expulsion of air or pressure reading on gauge. If pump is working then you probably have a clogged air release valve and maybe a clogged gauge. Just remove air relief assembly from filter top, remove gauge and clear any obstructions in parts. You should easily be able to blow air thru assy with gauge removed. Teflon tape the components and snug them back in their places. restart your pump and voila! air will come out when prime is established.
  • amanforallre Apr 25, 2009
    My other solution does not appear to be visible, to me at least. Heres a recap. If pump moves water normally, then the problem is a clogged air relief fitting on top of filter. Remove gauge.Unscrew assembly from lid and blow thru it. If clear, insert a thin pick down the hole on filter lid. Turn on pump for a couple of seconds or until water gushes forth and then turn off, of course.Tape up the fitting and gauge and reinstall gently. good luck
Have a sta rite cartridge with very clear water but the air bleed filter keeps getting clogged
you are missing the screen filter on the top of the long plastic tube
Jul 22, 2014 | Sta Rite Pool & Spa
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Pump is running but not returning water to pool
If you have suction, you must have discharge. It is a law. Your water is going somewhere. Check for your water going to waste. Are you CERTAIN you have suction ? When I first read your question, I suspected a impeller with a spun out center. The motor runs but there is no pressure and no flow.
Let me know ...
Nov 26, 2012 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
I have a sta-rite plm100 pool filter. I put in a new filter cartridge and now i have no pressure in my pool. what could cause this?
there might be trash in your impeller, and remember to always prime the pump after a repair. you can try running it without the filter in it as a check. and bleed off the air in the filter as you are running it also
Jun 29, 2012 | Sta Rite Pool & Spa
Bear with me. my son has a above ground pool sta-rite system model JWPA5E7L-2A2 pump. he says the pump is running and sounds normal but he has very low suction and exhaust pressure. any ideas before I go...
Be sure that the pump gets primed, not always easy. Sometimes you need to examine the pump impeller. Debris sometimes restricts in this area.
look for an air bleed, near the pump, if you find one, you can bleed air there...
IF your system has to lift the water over the edge, as opposed to through the side, bleeding the air requires patience, sometimes. The pump quits pumping when it gets any air << an issue if you use a vacuum hose, you need to TOTALLY bleed the air out of the temporary hose, before hooking it up....
I hope this helps. Keep after it, you really NEED good filtering flow for clean water. After you finally get it going, have people put their hand over the discharge end of the system and make note of the volume and pressure felt there.... When taking in air or not pumping, it will be obvious.
May 14, 2011 | Sta Rite Pool & Spa
I replaced the sand in the filter and had the gasket replaced. When I turn the pump on no matter what the setting all of the water comes out the waste port on the pump. I am getting very little water out...
Check your skimmer and pump basket for an obstruction that might be causing your lack of water flow to and from the pool. There could also be a restriction in your intake/return lines. Also, check for air intake in the return line (cracks or breaks). Any one of these issues could be causing problems with these sand pool filters.
Jul 12, 2010 | Sta Rite Sta - Rite 21" Above Ground Sand...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Apr 04, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System Logo
357 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
