Replaced imaging unit but error message still appears calling for service
Put in new imaging unit but error message still shows on panel of my cf2002
  • 145 Answers
Plug the machine for 20 sec ,and plug it back in than make sure the imaging unit is inserted in corect.if all fail,that mean s you have a bad or used imaging uint..
Posted on May 05, 2009
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Errore c 0208 minolta cf2002
High Voltage Board might have gone bad. IF you can find a replacement board. A legacy Minolta machine. Minolta is now Konicaminolta 3rd party best bet! mite reset all the image units, try.
Oct 03, 2012 | Minolta Office Equipment & Supplies
Samsung scx6555n showing error #31-007
I have encountered this problem twice on the same machine with different imaging units. I haven't received an answer from Samsung (presumably they will fix with a firmware update, their solution to everything) but the message and the red light can be cleared by powering down, reseating the the IU and powering back up. The good news is the user can still use the machine, even with the code.
Sep 13, 2012 | Samsung SAMSUNG SCX6555N LASER...
Xerox Phaser Printer has an error message cyan imaging defected, the unit was replaced with a new one, still getting message
There is a list of different parts that can be causing this error.
The first one is if its not seated properly. You can take it out and put it back in to make sure it is seated. Having bought a new one means that this is the only simple solution to this problem.
Here are the different parts that may need to be replaced as per the service manual states:
the imaging unit sensor board
the CTG0 harness
the engine control board
imaging unit motor
the lift uplink
the motor driver board
the low voltage power supply
!! that't a lot of possibilities and there are a series of electrical and mechanical tests that must be performed. You will have to call for service. Unless its seated incorrectly.
May 20, 2012 | Xerox Phaser 7400/N Printer
Call for Service error message E1-12
hi E1-12 for image processing unit ,
thanks
May 14, 2010 | Sharp AR-235 Copier
The printer is a Konika Minolta cf2002 DIALTA Colour, after initialising, the printer gives error code c0016 and 31C-M if the printer reports ready, when you sent a document it does not rpint, instead it...
The C0016 code means that the Black Imagine Unit's Motor is not turning. So you will need to check all the connections and connectors on the black imaging unit and try re-installing. You could replace it if you have a spare.
The 31C-M code is not in my service manual and I have never seen that code before.
Jan 02, 2010 | Office Equipment & Supplies
CALL FOR SERVICE MESSAGE ON A MURATEC MFX1200
Yes the Call Service Message on Muratec is directly tied to Imaging Unit replacment. Especially if you are not getting any codes in the display.
Oct 20, 2009 | Muratec F320 Plain Paper LED Fax
I have a xerox 7750, error code 9-913
This problem occurs when you buy the wrong image unit.
The contact chip that is located at the bottom of the orange plastic is not for the machine. Replace it with 7750 image unit and that should fix your problem. Black is fault 9-910 cyan fault : 9-911 magenta fault: 9-912 yellor 9-913.
Sep 24, 2009 | Xerox Phaser 7750DN Laser Printer
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Feb 12, 2008 | Xerox Phaser 6200N Laser Printer
139 people viewed this question
jasbo
jasbo
