Question about Bunn BTX-B ThermoFresh 10-Cup Home Thermal Carafe Coffee Brewer, Black
GFi breaker blows
Bunn btxb coffee maker trips GFi breaker. It appears that after the water in the tank reaches temp and the main heater shuts down the breaker trips. There is a secondary heater (I think) to maintain the tank temp. Happens on any circuit protected by GFi. Another pot (Gevalia) with different brew technology works fine.
  • 189 Answers
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Posted on May 19, 2010
Our bunn coffee pot trips the gfci and leaks water out of bottom of unit, why?
the water maybe wetted some electrical parts or ur tank heater faulty
Jun 24, 2014 | Bunn NHB Coffee Maker
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
May 06, 2011 | Bunn GR10 Coffee Maker
When coffee maker plugged into outlet it instanlty trips the GFI circuit when the tank heater button is turned on
You my friend have an internal short and should not be using that coffee maker. Either send it in to be repaired or replace the maker.
Jan 07, 2011 | Bunn GR10 Coffee Maker
How to fix a bunn coffee maker that trips a gfi
Every time I plug in my bunn coffee maker, it trips the GFI. But when I plug it into another plug in my kitchen, it will work, but it seems like the water reserve is not right. It blows too much steam and the top starts lifting up from the pressure of the steam, then it starts leaking out the top left side. Then if I pour enough water to make 10 cups, it only makes 6 or 8. The coffee maker is only 3 years old, what should I do?
Aug 01, 2010 | Bunn NHB Coffee Maker
Gfi in kitchen blows when pluggung in coffee maker
either gfi is on an overloaded circut or the gfi is bad....the heater on a coffee maker uses alot of amps / you may wanna try a different plug
Jan 03, 2010 | Bunn BTX 10-Cup Coffee Maker
Bunn coffee maker leaks water only during operation...near end of the cycle (not when it just sits & not when water is first added).
There is a gasket where the water inters the tank,you have to remove the tank to get to it .mark down how it is wired so you can hook it back up.Use a high-temp
silacone ( auto ) and seal it under the the gasket and around the edge of the gasket.. 2 screws holding the metal plate plate. 4 screws holding tank need a 12 or 14 " phillips to reach down on the side of the tank to remove outer cover.
Oct 08, 2009 | Bunn NHB Coffee Maker
When i plug it in it trips my gfi and it is not on
This can be caused by one of two things. (1) The GFI plug has a problem: it could be broken behind the face plate, or some of the wires in the box are so close that when you push a plug into the outlet, they touch and trip the GFI. (2) The other source is due to a defect in the appliance between the cord and the power switch. That is why the GFI faults even before it the coffee maker is turned on.
Have the outlet checked thoroughly and make any needed adjustments / repair /replacement and reconnect the coffee maker again. If it trips, the coffee maker will need to be serviced. DO NOT use the coffee maker in another non-GFI outlet until it has been checked out. The chances of electrical shock or burns is significant until the problem is found and corrected.
Oct 02, 2009 | Bunn Coffee Makers & Espresso Machines
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Mar 31, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Oct 27, 2007 | Bunn RL Coffee Maker
Coffee Makers & Espresso Machines Logo
1,128 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
