Question about Video Game Consoles & Games
Error code 101-0105 support information 1,4.0.0U ,2,WHO-101(02) ,3,FW405827196 ,4,AEC7-0200-3350
How to repair error codes on meistergram pro 1500 embroidery machine
Are you asking what an Error Code means and then how to fix the cause?
Error Information...
In case of incorrect operation or machine malfunction, the screen will display the
description of error or icons to inform you.
CL key [CL] Clearing...
This key is used for clearing errors, information or data such as stitch count and frame
coordinates.
Error codes are in the Single Manual (final) pages 68 thru 73
Download this manual's .pdf file...:
http://www.pantograms.com/images/meistergram/Meistergram_Single_Manual_Final.pdf
Feb 08, 2015 | Sewing Machines
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
Is there a sight to find frigidaire built in oven error codes
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand you are seeking a site that provides a listing of error codes on your Frigidaire oven. This information is very rare to find. Is your oven receiving an error code? If so, may I have the error code and with this information I'll be more than happy to help you narrow down the possibilities of the code. Thank you!
Aug 02, 2014 | Frigidaire Ovens
F2 ERROR
F2 04 Content Improper cartridge (Destination error, life cycle
error)
Detail The destination of the machine differs from that
of the CRUM.
The life cycle information is other than "Not
used (FFh)."
Cause CRUM chip defect
Improper developing unit
Check
and
remedy
Replace the CRUM chip.
Replace the developing unit.
Identificat
ion error
The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model
error
The boot program model code does not
coincide with the CRUM model code.
Type error When the CRUM type is other than genuine/
conversion/production rotation.
Destinatio
n error
The machine destination differs from the
CRUM destination.
Data
abnormali
ty
When an error value is included in the initial
check information. When the max. toner supply
time is 00.
When the print hard stop is 00.
Misc error When the Misc information is other than "Not
used (FFh)
Feb 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Solution for f2 error code
F2 - 04 : Improper cartridge (Destination error, life cycle error)
Detail : The destination of the machine differs from that of the CRUM.
The life cycle information is other than "Not used (FFh)."
Cause : CRUM chip defect - Improper developing unit
Check and remedy : Replace the CRUM chip - Replace the developing unit.
Identificat ion error : The trade mark code of the CRUM differs.
Model error : The boot program model code does not coincide with the CRUM model code.
Type error : When the CRUM type is other than genuine/conversion/production rotation .
Destination error : The machine destination differs from the CRUM destination.
Data abnormality : When an error value is included in the initial
check information. When the max. toner supply time is 00.
Misc error : When the Misc information is other than "Not used (FFh)."
Oct 20, 2012 | Sharp AR-M160 Laser Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error code: 51100
"error code 51100" that is great information..... what device are you gettng this code from. to just put of "error code 51100" is not information to get an answer. you should be contacting the manafacture of whatever product you are having this error code from.
Mar 08, 2011 | Video Game Consoles & Games
Ok..... my wii isnt letting me connect and i dont know what error code: 51032 means can u help me?
I have found this information regarding the Error Code: 51032. Along with the definition of the code, it also supplies some information on how to attempt to fix the problem. Hopefully this helps!
Error Code: 51032
-Dan
Mar 05, 2011 | Video Game Consoles & Games
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
Feb 28, 2011 | Office Equipment & Supplies
Video Game Consoles & Games Logo
139 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
