Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
E372B Fridge and Freezer ( fisher paykel)
E372B.Light will not operate when door open.Door alarm no go when door open,Temperature display will not illuminate.Making loot of noise.Compressor works ok.Freezer cooling ok.upper compartment not cooing enough.Its stuck on Sabbath Mode.Tried to reset it as per manual still no go Please advise fault.
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
stephanos18
  • 144 Answers
SOURCE: E372B FISHER & PAYKEL FRIDGE WARM
I'd say you most likely need a new defrost element and evaporator Chassis. You'll most likely find there's a big lump of ice behind the evaporator chassis in the freezer inturn blocking the fridge vent or the defrost element is burnt out icing up te Evaporator. It pays to replace both anyway you'll need to unplug the unit and leave the doors opens for 48hrs to defrost it first. cheers
Posted on May 16, 2009
heatman101
  • 43501 Answers
SOURCE: The freezer (bottom) compartment of
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
heatman101
  • 43501 Answers
SOURCE: Fridge compartment not cooling. Freezer
heatman101
Posted on Jan 07, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Fisher and Paykel E372B frig.freezer
Download this manual and see page 18:
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/814943_Mandarin_Ref_Eng_UC.pdf
It tells you to push the runners back into the refrigerator. The manual shows lifting the front of the trays or bins for removal and installation should be in reverse order of removal.
Since your having problems see if you can get the runners to slide out. IF they will not slide out try lifting the runners straight up carefully if there is too much resistance and you feel the runner might break STOP.
You can contact them using this link:
Thanks for choosing FixYa,
Kelly
Posted on Mar 24, 2011
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
The door alarm of my fisher and Paykel E372B fridge goes off when the door hasnt been opened for a number of hours. How can I stop this.
You would notice that when it beeps, there are a series of beeps, which relate to an error code - also, the temperature panel would be most likely flashing the same amount of times the beeping occurs. The code relates to a component failure that the active smart system is having problems with.
For example, 17 beeps would be error code 17 - which relates to the freezer fan is drawing less current than is expected. Either the wiring is open circuit or the fan is faulty.
Feb 18, 2015 | Fisher and Paykel Refrigerators
How do I deactivate the open door beeper?
You can try this special mode, but it will disable the interior lights as well.
You will be required to have both the fridge & freezer doors open, and to push and hold the compartment select MODE button on the display board for 10 seconds.
When the cabinet is in this special option mode the following will not operate:
  • The interior light will not turn on when the PC door is opened.
  • There will be no set temperature lights (LEDs) displayed on the display module.
  • The door alarm will be disconnected and will not sound even if the doors were to be left open.
NOTE: When in the special option mode, the fridge icon will be illuminated, indicating that the appliance is in this mode.
To cancel, you can exit this mode at anytime by pushing and holding the compartment select MODE button for 10 seconds. If not exited manually, the refrigerator will automatically exit this mode after 80 hours.
Oct 05, 2014 | Fisher and Paykel Refrigerators
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
ELSE
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Carnac the Magnificent
Jul 28, 2017 | Fisher Refrigerators
Refridgerator E249T the beeping alarm wont stop. The door appears okay. How can I disconnect the alarm, please? Thanks Brian
I have the same fridge. It was driving me crazy. I emptied it. Cleaned it. Defrosted it. And was ready to dump it. Then worked it out. As it beeps when the door is open. How does it know. Because when the door is open the light is on. I taped up the light nob with masking tape, on top left of fridge. No light now
But no beep Yay!!!!
Jun 14, 2010 | Fisher and Paykel Fisher Paykel DD24DCB6...
May 16, 2009 | Fisher Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
398 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
