Rjp63f3 equivalent - Televison & Video
Equivalence transistor tt2206
Equivalent Sanyo 2S?5793
Features : I(c) : 10A, V(cbo) : 1600V
1. High speed.
2. High breakdown voltage (Vcbo=1600V, Vceo=800V, Ic=10A, Pc=65W ).
3. High reliability (Adoption of HVP process).
4. Adoption of MBIT process.
TT2206 equivalent circuit is 2S?5793, TT2202, JL6920, 2SC5446
Dec 19, 2016 | Televison & Video
What is the equivalent fraction to 0/2?
If we have no pizza, and divided it between you and me, how much do we get? ZERO.
However, you want equivalent fractions to 0/2. To get an equivalent fraction, you multiply the numerator (the number on the top) and the denominator (the number on the bottom) by the same number.
So we can multiply the top and bottom by 2.
0 x 2 = 0
2 x 2 = 4
So an equivalent fraction would be 0/4.
Good luck.
Paul
Mar 18, 2015 | Office Equipment & Supplies
What's a number equivalent to 100 using only the number nine
99.9999 repeating is technically equivalent to 100, depending on what level math you're in.
For example, 100 / 3 = 33.3333...
but clearly 33.333 * 3 = 99.9999...
So multiplying both sides of my first equation by 3, we get 100 = 99.9999
If you are not looking for "a number equivalent to 100" but "an equation or set of numbers equivalent to 100", then there are many ways. For example:
99 + 9/9 = 99 + 1
And 99 + 1 = 100
Jan 16, 2014 | RXE160 Equivalent NTE16013-ECG POLYMERIC...
Please, Searching the replacement for this transistor RJP63F3 it's in a Inverter Board of a TV set PLASMA SAMSUNG TV 42 " model: PL42B430P2XZL Thanks a Lot. Klauss klauss474@hotmail.es
You can go to;
http://www.1sourcecomponents.com/search/search.htm
and enter the part number.
> Get the data sheet for the item if it is not the original manufacturer.
> Make sure the pin out on the replacement can be used in your application. Sometime they change them.
> Make sure the packaging can be used in your application.
Mar 08, 2011 | Televison & Video
1) Minolta XG1 35mm Film Camera 2)Minolta X300 35mm Film Camera Which batteries can I use for the cameras listed above?
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Feb 17, 2011 | Konica Minolta X300 35mm Film Camera
My tv is switching on but no picture and looking 4 spares rjh30f2 and rjp63f3
RJP63F3 transistor
You can go to;
Nov 19, 2010 | Televison & Video
What are pentium III Equivalents
Athlon 1.3GHz cpu
Celeron 300A processor.
These are a few and courtesy of Tech Enclave here is a link about a place in China that produced a CPU called Godson II which is the equvalent of a Pentium III as well.
http://www.techenclave.com/cpu-mobo-corner/chinese-made-cpu-chip-equivalent-pentium-2595.html
Hope this helps.
Feb 27, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Televison & Video Logo
545 people viewed this question
Top Televison & Video Experts
Electro Med Services...
