Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Thermal fuse Where can I buy the ceramic thermal fuse for panasonic pt-4012lc Spec: 250V 5A 115C Thank you
I purchased a NTE8115 from my electronics supplier, closest I could find.  Radio shack also has them.
Posted on Oct 30, 2007
TV IS OFF BUT HAS A GLOW ON THE SCREEN
replace capacitor ceramic 473j 250V beside plug yoke.
Apr 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I need to get some ceramic fuses for my big screen tv
Hi josebalbuena
You can buy ceramic fuses from here. They are in most countries of the world. If you could give me more information, exactly what is written on the fuse you require,I could pinpoint the exact one for you. Happy to talk to you further about this.
Regards robotek
Apr 08, 2009 | Philips Televison & Video
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Need to find a ceramic fuse T5H250V
REPLACE THE POWER SUPPLY.THEY ARE RELATIVELY CHEAP.AROUND 30 TO 40 DOLLARS.
Mar 07, 2009 | Computers & Internet
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Thermal fuse
It is mounted to the case that holds the lamp.. Its specs read something like L3 250V, 5A, 115C. You can replace it provided you can locate it
Jul 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
PT-40LC12 fuse problem
I went here for a tech manual for the Panasonic tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
mine is broken again. this is getting old between lamps and repairs.
Oct 24, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-45lc problem
I took the rear bottom off of the set,lots of screws to take off.
On top of the bulb housing is a small yellowish thermal fuse.
I took mine completey out,jumped the black wire together,and bingo.set works perfectly.
Aug 31, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Apr 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
282 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
