Question about Mantis 2-Cycle Tiller
2 cycle mantis tiller leaks gas thru the carb. - will not start?
  • 2 more comments
  • jhertter70 Apr 24, 2009
    Bulb and gas lines are OK why does gas leak out the Carb.? I ran the tiller yesterday but today it will not start and the entire gas tank emptied out thru the Carb. I have not adjusted anything
  • josh1111 May 11, 2010
    yea you need to take the carb apart and inspect it and clean it. mabey a gasket is bad. where is it leaking from on the carb? the gas is supposed to go trhu the carb and shott into the engine on top of piston( which it isnt getting to enginez0
  • Benelatus May 11, 2010
    OK,
    I'm fairly sure that the problem is due to some gunge from the fuel tank either jamming the float valve down so's it "thinks" there's no fuel in the tank, or else there's a hole appeared in the float, and that's what's holding it down.
    The problem now is :- are you sufficiently skilled to take the carburrettor to pieces?
    is all your fuel lines in good shape and primer bulb? have you tried to adjust the carb?
  • 45 Answers
If it leaks gas,it can **** air.you have to find out whats leaking and stop it.
Posted on Apr 29, 2009
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
I have a Mantis old Mantis tiller, which is working, but leaks gas from the carb after it has been shut down.
you can do this on your own all you need to do is blow it out with a air commpressor
Jan 28, 2013 | Mantis 2-Cycle Tiller
Mantis tiller starts rt up, good idle no power,new fuel lines plug,filters,rebuilt carb,when trying to rev bubbles in gas tank?
Check that the fuel filter is sitting near the bottom of the tank, and not somehow being held near the top of the tank.
Jun 11, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
My mantis runs roughly for a short while then
carb may need work but change the air filter possible not letting thru air
Apr 21, 2010 | Mantis 2-Cycle Tiller
most carb problems can be remedied with a carb. kit & cleaning.
However, this problem is solved by replacing the carb. 95% of the time.
not exactly what you wanted to hear.
Sep 09, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Mantis tiller 2 cycle seemed as if it was running out of gas
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Mar 20, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
1,261 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
