Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Ge profile model tcs18 bottom freezer - refrigerator part does not cool enough. some air comes out of bottom section of refrigerator, but does not cool upper portion of refrigerator
SOURCE: ge refrigerator model TFH22JW problem
You most likely have an automatic defrost problem. When one of more of the defrost components fails, frost accumulates behind the freezer wall and restricts airflow to the fresh food side. You will still generate cold into the freezer section but will have virtually no cold to fresh food side. If it is a few years old it is most likely the defrost heater which is defective. Replace the defrost thermostat (bi-metal) as well.
Posted on Oct 02, 2007
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator will not cool
Unplug power, pull refrigerator away from wall and gently remove and examine both sides of control board, Look for burn marks or smell of burns and then let me know what you find. Thanks, Sea Breeze
Posted on Mar 25, 2009
SOURCE: Hello I have a GE
The drain is frozen up. The fan what provides the cooling air for the fridge is stuck in the ice. Remove the vegie crisper and pop the bottom under the crisper s out. Also remove the Styrofoam plate. You will see the problem right in front of you. Use a hairdryer to get rid of the ice build up. Good luck
Posted on Jan 23, 2011
Where is the defrost heater located in my GE Profile model TCS18?
defrost heater is located inside of ref. freezer take out shefs and racks.should be screws on back plate remove plate and derost heateris is normally mounter at bottom of coils .ge still uses glase heaters.google model no. for correct part
Apr 10, 2013 | Refrigerators
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
Nov 10, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
Our G E Profile TCS18 freezer works but the top of the Fridge doesn't cool. No cold air comes from the top inside vents in the fridge.
when you open the freezer,do you hear the fan blowing air around,the evap fan motor could be bad or you could have a blocked drain and the water froze icing up the fan blade
Jan 30, 2010 | GE Refrigerators
Oct 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
