Question about Home
Aquus bathtub where do I find replacement plastic parts that have yellowed for a 1995 AQUUS TUB?
4 Suggested Answers
  • 80 Answers
SOURCE: need replacement parts for a
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
Posted on Aug 12, 2010
rockmeister
  • 2047 Answers
SOURCE: Hi. I have a "Aquus"
Usually depending on the model i would advice you just get replacement springs. But considering that the fact that the unit was original to the home it could be custom. And considering you have the house up for sale you would need a professional work done. here are a couple of contacts who can help with the repairs.
The Pool Doctor
126 State Route 37
Danbury, CT 06812-4013
Phone: (203) 746-7665
Salvatore Plumbing LLC
(203) 792-9831
178 Osborne St Ste 2
Danbury, CT
Carmine's Plumbing Heating & Air Conditioning LLC
203-791-8089
92 Sand Pit Rd
Danbury, CT 06810
Peter Hornik Plumbing & Heating Services LLC
203-748-7377
145 Westville Ave
Danbury, CT 06810
One of the above should be able to fix it for you. They are all experts in the field of whirlpools.
Hope this solution has been helpful?
Posted on Jul 07, 2011
  • 39 Answers
SOURCE: Does the bathtub 60"L x 42"W Almond Tub come with armrests?
Yes this model does come with built-in arm rests. See this link for details http://www.efaucets.com/detail.asp?Product_ID=71111122-47&ca=shopz
Posted on Jul 15, 2012
Where do i get parts for ez bath
If you can blow into the tubing and start the motor then you need to replace the air button on the tub.
Rod
US Parts Center
888-521-6183
Apr 22, 2013 | Ez Access Inflatable Bath Tub Ez Bathe...
I have a corner whirlpool tub and the pump is leaking water when it is on high. I am trying to find a parts supplier to repair myself
sounds like you need maybe pump union o-rings, part # o-49 or the seal might be leaking. If the water is leaking between the plastic wet end and the motor then it is definitely the seal kit which costs about $30 however on a bathtub most pump mfg have quit making replacement parts for them. You will most likely need a new pump in that case. If you can let us know what brand of pump we can assist you in repair or replacement.
US Parts Center
Aug 08, 2011 | Whirlpool Home
We have a whirlpool tub with jets and the mice have eaten the plastic air tubing. what can we do
All of the parts of a Whirlpool tub are replacable. you can go to Whirlpool.com and call customer service to get part #s and order or you can patch the hose with applicable materials from a home repair store such as Home Depot or Lowes.
Jun 12, 2011 | Whirlpool Home
Need replacement parts for a MAAX WESTCO INC A159869 8Z31 Jet Bath Tub Would like to replace the white plastic parts in side the tub with chrome as they have turned yellow
Aug 11, 2010 | Home
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
I have the the aqualux whirlpool tub, do i disconnect the side square filter to clean, there is a screw in the middle of the tub. it have turned yellow. do i clean it or leave it alone. how do i cleam the...
The square filter on the side it tough to get off because of a rubber seal the runs around it. However, once the screw is removed there isn't anything else holding it on. You're going to feel like you're getting ready to break something, but you'll have to work with it to get it off. You might try a flat head screwdriver or a razor and carefully run it between the seal and the tub to loosen it. It will come off, it's just a little bit hard. When you remove it, you'll see why it was so hard to get off...the soapscum is all over the inside of it and some of it hardens around the seal in spots. Hope this helps.
Mar 24, 2009 | Home
Jacuzzi tub on/off bezel wont hold switch down
I couldn't find the information you are asking for in the installation manual. I have included a link to the pdf page so you can print it out and look at it in print. On this particular question, I think I would give Jacuzzi a call. They can better answer you question without guessing.
http://jacuzzi.com/pdf/K272000.PDF?SELINSTMANS=K272000.PDF&goinst.x=15&goinst.y=8
Mar 22, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
356 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
