Question about Campbell Hausfeld 3.5 Hp 20 Gallon Air Compressor Vt-6183
Campbell Hausfeld 3.5 Hp 20 Gallon Air Compressor dk-133410
  • 1388 Answers
SOURCE: high/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Posted on Jan 21, 2009
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
roniecon
  • 6927 Answers
SOURCE: campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Posted on Oct 05, 2009
  • 73 Answers
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Posted on Oct 17, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
I have a campbell hausfeld 60 gallon compressor 20 amp motor what size breaker should be used
I am not a master electrician but I was an apprentice for 5 years and think you should be ok with a 30 amp breaker. anything less and you may be resetting the breaker when the unit first turns on. Dont forget 30 amp breakers will require # 10 wire or larger, #12 just wont do.
Oct 29, 2010 | Campbell Hausfeld Maxus 60 Gallon (Belt...
I need an owners manual.
plz follow this link and choose your model and get the manuals.
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=FP2080
i hope u will get the solution.
Oct 29, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Campbell hausfeld mod wl611700aj runs for 3-5sec
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Piston snaped on my husky 1.7 hp 32 gallon
I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Campbell Hausfeld 3.5 Hp 20 Gallon Air Compressor Vt-6183 Logo
67 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
