Remote control code for wd-65638 - Televison & Video
bugoy31
  • 1238 Answers
SOURCE: mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
I think you need to download the manual for you to easy follow how it works...
try this link:
http://safemanuals.com/user-guide-instructions-owner-manual/MITSUBISHI/WD-65638-_E
try to click the right box and click the boy to the left side...rate and comment then download..
Posted on Dec 19, 2011
gopakumarg43
  • 75581 Answers
SOURCE: My Mitsubishi t.v model number wd-65638 won't turn
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Posted on Jun 04, 2014
  • 116 Answers
SOURCE: Mitsubishi dlp wd-65638 with error code 61. What is this error code? How do I fix? no picture or audio.
if the power LED is flashing green then there is a circuit or board that either has a blown fuse or relay. if it comes on solid red when you turn on the television then the Lamp inside is burned out and needs replaced. Before you spend all the money that changing the bulb would cost i would invest that money in a good LED Smart TV instead. Sometimes you just gotta let that old technology go away.
Posted on Dec 30, 2014
  • 5631 Answers
SOURCE: Model WD-65638. What are the instructions for programming remote?
If you have the original remote of your TV, it doesn't need to be pregrammed. If doesn't work, it's defective.
If you want to program a universal remote, you need the codes of the remote for your TV. If you don't have the manual you should look for it using google with terms
Manual make and model of remote
If you have a manual and no codes for your TV, follow the prodedure indicated to scan your TV with the remote till you find the code or cover all the range of the remote without getting a working code.
Posted on Sep 28, 2015
  • 10291 Answers
SOURCE: I nee small squirm cage fan for mitsu bishi and How to change it model wd-65638
http://www.shopjimmy.com/mitsubishi-299p321020-fan.htm You can get the fan here.
Posted on Dec 18, 2016
65 in wd-65638 looks like dirt inside the scrin
Its not dirt, the light engine is failing and this part is not cheap.
Feb 06, 2016 | Mitsubishi WD-65638 65" DLP HDTV
Really dim picture
check your bulb life, there is a way to do that using your remote
Jan 26, 2016 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
Sep 28, 2015 | Televison & Video
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
Dec 30, 2014 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
Mitsubishi WD-65638 turns itself off and I see no status codes afterwards
Press menu and input on front of TV for 5 seconds. Green light will flash two digit code 5 times. '12' is no error(no problem.)
May 22, 2014 | Mitsubishi WD-65638 65" DLP HDTV
I have a mitsubishi wd 65638 . it powers up just fine then about an hour or so in it starts to slutter the colors then settles into a weird silver and grey colors setting like black and white but not
this sounds ilke the board maybe tring to go bad although i know it doe have colored bulbs but it has to be the circuit board this is what control the power distabution
Apr 09, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi wd-65638 dlp tv error codes sound no picture replaced the bulb I get a code of 6 blinking red and 1 blinking yellow
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help.
Blinking codes to Mitsubishi PTVs are given in detail.
Apr 10, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
try this link:
Dec 11, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
