Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Water will not drain from Kitchen Aid Dishwasher
Water will not drain after wash cycle
Kitchen Aid makes the worst appliances on the market. Never buy them, they should stick to mixers. My dishwasher doesn't drain, the glass on my convention microwave/oven shattered in the middle of the night, the freezer doesn't freeze. Service calls too many times to count the first year and absolutely no customer service after the first year was up.
Posted on May 03, 2012
    Problem Solver:
  • 3 Answers
My dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: I have a Kitchen Aid
when "full" of water, the normal height of level is about 1/2 below the heater assy(large blackish grey coil below he spray arm).. if theres enough water in the unit nad its still not "spraying",its quite possible that your filter/chopper assy is clogged and cant let water through. try removing hte spray arm and under that you will see 5 torx15 screrw holding down top filter plate under there to the left youll see another t15 screw covering hte chopper assy area. claen out sump of debris this may be your issue
Posted on Nov 26, 2008
  • 670 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
  • 4088 Answers
SOURCE: 5 y/o kitchen aid dishwasher was wroking great now
Unless someone turned the supply off under the sink, the water fill solenoid is likely defective. It should be located near the area where the fill hose connects to the machine. Make sure to shut the power off by unplugging or turning the appropriate breaker off. Hope this helps.
Posted on Feb 21, 2010
Daniel S
  • 4323 Answers
SOURCE: Hum in Kitchen Aid Dishwasher Model 8531529.
Hi
The hum sound that you hear is from the motor that is not working or is about to go out, the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 21, 2011
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
How do I remove the suds after having used regular dishsoap instead of dishwasher soap?Kitchen aid dishwasher
you will just need to run it a few times. I know of no way to kill bubbles except to dilute them.
Oct 13, 2014 | KitchenAid Kitchen Aid - KUDS30FXBL...
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Feb 21, 2008 | Dishwashers
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
2,081 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
