Some of the eurekas ha screws on the top of the base to remove the cover.others have the screws on the bottom.if they are on the bottom there will be 5 screws1 on each en of the roller in front and 2 on each end of the roller behind the brush and 1on the rear of the bottom plate where yo can see where the belt guide is.make sure you clean the old rubber off the motor shaft or your new belt won't last
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610 Eureka replacement (Central vac bag) another genuine bag style called CV-1, and/or CV-2 Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A) And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880 Hope this helps you.
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Either go directly to the Eureka internet site, or GOOGLE "eureka boss smart pet lover manual". Several options should be displayed to download the needed manual.
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Remove the two screws on the top of the hood, usually hidden amongst the four little holes on either side of the top of the hood. This should allow you to lift the hood away and access the belt and brushroll.
