Question about Uniden Solara DSC VHF Marine Radio
Cannot get international channels - Uniden Solara DSC VHF Marine Radio
  • Uniden Master
  • 696 Answers
From the owners manual (Page 4, link below) Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same time to change channel modes from USA to INTERNATIONAL to CANADIAN.
-Steve
http://www.uniden.com/pdf/SOLARA%20DSC-BKom.pdf
Posted on Mar 11, 2015
Internally change channel 3 to 4 on VCR
Hi, In most VCRs, as you have posted, there is a switch at the back where you can select the output to either Ch 3 or 4. In some cases, the switch is deep inside and you have to remove a small squarish rubber covering to expose the hole. It is normally close to the antenna input/output. More often than not it is a simple sliding 2 position switch. You would need any tool that can reach and sturdy enough to slide the switch. Internally program output channel selector is very possible, I would guess that its selectable via the menu set-up tabs. A question pls, How did you "I tried to manually change the channel to 4, but the VCR reverted back to channel 3..." Hope this be of some help to you. Pls post again how things turn up or further information. Good luck and kind regards.
Aug 01, 2007 | Quasar VHQ401 VHS VCR
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
Denon avr1200 G ----one speaker channel stopped working....
Hello
Check the speaker first. Connect an other box to the output now seems dead. If this does not help you, it is best to get this set repaired by any experienced service technician. It internal amp circuit will have the trouble. The circuit of this set is very complicated, as only a well expereienced only can set it right. There is no internal fuse for outputs to this set.
Feb 26, 2012 | Denon AVR-1200 Receiver
I fitted a Peak dvb-t digital tv usb stick with an ariel included and it doesnt pick up any channels. if i fit an internal tv card will that work instead please?
IN GENERAL these decives don't have decent reception when working in side and with the internal ariel. If you can use an external roof fitted ariel you will get better recpetion. I even had a dedicated portable tv that didn't receive all channels, in France, due to the inferior internal antenna.
Jul 05, 2011 | Computers & Internet
I have a Raymarine Ray 54 vhf radio at my beach house. Apparently the local station to listen to marine is 77. I can get 77 but it does not come up International I have been told that in order to get...
Hi!
Channel 77 (156.875 mHz) is the same frequency on BOTH US and International channels and is generally used for Port Operations. I see no need whatsoever for you to bother with the International designation.
Hope this helps.
Jan 16, 2011 | Radio Communications
Lost the spring that holds the staples in model strapgun 12-14 how can i get new 1
No spring needed
Turn staplegun upside down. At
rear of tool, squeeze latch on
end of staple channel (see Fig-
ure 4). Pull staple channel cover
out of staple channel until it stops
(see Figure 4).
3. Drop staples into staple
channel. Make sure staple
points are facing up (see
Figure 4).
4. Slide staple channel cover
back into staple channel until it
Aug 05, 2010 | Desa International Powerfast Heavy Duty...
Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
Nov 25, 2009 | Audio Players & Recorders
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
I have a poloriad flat lcd tv now channel 40 is the only channel where their is not sound all other channels have sound. We have cable and our other tv on channel 40 is ok but on the poloriad no sound on...
Could be the tuning of channel . Try doing an automatic channel search again and see if it will tune in more closely and get the full audio level.
Also, you might try a hard reset of the internal soft codes by unplugging it overnight to allow all the internal emproms to reset.
If the cable is passing through a vcr, could be the vcr at fault, too.
Jan 17, 2009 | Polaroid FLM-323B Television
Uniden Solara DSC VHF Marine Radio Logo
125 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
Mike Marcotte
Mike Marcotte
Are you an Uniden Boating Expert? Answer questions, earn points and help others
