Question about Kwikset Professional Door Lock installation Kit
I am trying to remove the cover of the kwikset chelsea deadbolt lock. There is no tab to lever it off.
cartersintn
  • 62 Answers
SOURCE: My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Posted on Apr 13, 2009
  • 10 Answers
SOURCE: Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
Posted on May 22, 2009
rsmith972278
  • 160 Answers
SOURCE: WHERE CAN i FIND A MANUAL FOR MY kWIKSET SIGNATURE
I think this is what your looking for... click link below.
http://www.kwikset.com/smartseries/smartcode.aspx
click on the correct link to your system at the bottom of the page when you get there.
Best,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Jan 21, 2010
SOURCE: Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Posted on Jan 31, 2010
  • 6 Answers
SOURCE: Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Posted on Apr 29, 2010
How to tighten kwikset #991LL
Remove inside lever by loosening the setscrew and pulling. Carefully pry off the inside cover. Make sure both screws are tight. Replace inside lever. With door unlocked, the outside lever can be removed in the same way as the inside. All that is necessary though is to be sure the setscrew on the outer lever is tight. Check to be sure the lock is tight and operating correctly before closing the door and locking it.
The deadbolt inside turnbutton is held on with a small setscrew. Remove it and the inside cover. Be sure the screws under the cover are tight. Check the lock operation, replace cover and turnbutton.
Jul 07, 2014 | Kwikset 991ll 15 Smt Cp Lido Entry Lever...
Deadbolt does not 'retract or extend' but can hear the wheel turning
The lock is covered for the lifetime from mechanical defects.
Here is the contact information:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Jun 29, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have a front door Kwikset "lever opening" front door key/deadbolt lock system which has come very loose, almost falling off. How do I tighten it up\?
on the inside of the door look on the bottom of the lock cover. There should be a hole with a screw or allen head screw. Remove the screw and you can access the the rest of the lock.
Feb 25, 2011 | Kwikset Professional Door Lock...
I have a kwikset deadbolt model 898 keyless entry.i need to change pin number on keypad outside
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Feb 04, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Replaced my transitor battery on my front door. push enter from outside the door enter turns green ......turn deadbolt and it locks. Tried to open door, push the lit numbers of " 4 digit code" enter key is...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Oct 21, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
I have had my Kwikset Powerbolt 1000 for about a year now and I think it just died! The deadbolt won't move. It will only move one out of every 25 times or so. I just replaced the batteries again. It makes...
Why is my Powerbolt beeping?
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Good luck--and please provide feedback if this helps!
Sep 20, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
Jan 23, 2009 | Kwikset Professional Door Lock...
Kwikset Professional Door Lock installation Kit Logo
48 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
