Question about Haier HWR05XC7 Wall/Window Air Conditioner
I simply need to change my setting from fan to cool without a remote! The unit is working fine, I just want cool air not just fan.
My delonghi air con unit has power, the green light is on showing there is power to the unit, the set temp buttons and timer buttons work but the on and off, mode, fan speed and swing buttons don't?
Seriously...
I suspect you are right... it OUGHT to work without the remote... BUT no model number came through with your question...
NEVER-THE-LESS... the cheapest... shortest path to being cool is the price of a remote...
I'd buy a SPARE (too = two)...!!
Later, at your leisure, you can RISK having a "professional"
look it over!
I'm just saying... Have we tried looking at the OWNERS MANUAL..?
Figure out what refrigerant you are using... Where to get a FREE manual (on-line)... Service & maintenance tools & REQUIREMENTS... (etc.)
Be cool!
Refrigerant Equipment Oil Label HVAC Refrigeration Pack of 10 Labels
Jul 24, 2016 | DeLonghi Heating & Cooling
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
I have a Whirlpool Model ACQ158XPO wall/window air conditioner. Motor comes on but it does not cool. Any suggestions?
Its really tough to troubleshoot window units without pulling the cover off. If I was standing there looking at it without tools in my hand I would first make sure the fan/cool switch was in the fan high cool mode and that the thermostat was turned all the way to the coolest setting. Beyond that it needs to go in for repair. Wish I could be more help. Good luck.
Oct 05, 2014 | Whirlpool ACQ158XP Wall/Window Air...
My remote will not change the fan speed on my mini split heat pump in the heat mode but will change speed in cooling mode. checked batteries and pressed restart button no changes
in the heat mode the fan mode run automatically first in low mode and after a while it run normally ,how you set on the remote.if you can-t set on the remote is possible to have problem to the remote.
Dec 12, 2013 | Comfort-Aire EHW 12 Air Conditioner
Outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Jan 08, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
Lost Remote
go here: http://www.partlinx.com/haier.asp
andsearch for the part. You have to start with your state, and then gofrom there. For my area, the remote is 19.99, plus shipping and tax.Also, try eBay. You can find a lot of things there!
Aug 24, 2008 | Haier hwr10xc6 Air Conditioner
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Failure during operation
No. The fan setting simply runs the fan full time bypassing the thermostat. In cooling mode the unit is slave to the thermostatic sensor located in the return air stream. If the unit is in a very small room or the exiting cool air is obstructed by furniture or curtains then the cool air is directed directly back to the sensor before mixing with the room air, causing erratic operation. Be sure several square feet of floor space is open in front of the unit and point the vent upwards and see if that makes a difference. Hope this was somewhat helpful, GL.
Jun 11, 2008 | Panasonic Room Air Conditioner CWXC104HU
Haier HWR05XC7 Wall/Window Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
