Question about Minolta Maxxum 5 QD 35mm SLR Camera
Wont shoot Hi, I have put my manual in a very safe place and can't find it! When I turn my camera on, it sounds like it is vibrating for about 3 seconds, then the red light shaped like a triangle on the back right hand side lights up and I cannot shoot a photo. I can get the menu to come up.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
The noise you hear is the auto focus motor and it does not seem to engage the lens properly ( via the drive port in the lens mount). The problem is either with the drive itself ( in the body ) or the lens. Switch auto focus off for now ( until you have the camera looked at ) and use in manual focus mode.
Posted on Sep 25, 2007
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
Tip
Manual Aperture Video For Canon Eos Rebel 500D T1i
Unfortunately the Canon T1i shoots video in full automatic mode. This means that if you want to change the depth of field...well, you can't. There are many angry T1i owners trying to get Canon to release a firmware update to have it perform like the T2i, but so far that has been fruitless.
So what can a budding videographer do get some artsy-looking footage with his or her T1i? The Band-Aid solution involves fooling the camera into thinking there is a manual lens attached so that the camera will relinquish control. To do this, the communication between the camera and lens has to be severed (don't worry - it doesn't involve modifying anything).
Step 1.
Put the camera into Av or Manual mode.
Step 2.
Select the desired aperture (if the aperture is "wide open" - e.g. F1.8 on the 50mm F1.8 II lens, then skip Step 3).
Step 3.
Press the depth of field preview button on the side of the camera (above the T1i or 500D logo on the curved part of the camera body).
Step 4.
With the DOF preview button still depressed, push the button as if to remove the lens, and turn it very slightly until "F00" shows up on the back display. You may now release the buttons.
Step 5.
Switch the camera to video mode. There will be a warning message, but just do as it says and shoot anyway.
You're now ready shoot some nice shallow DOF shots. Use the manual focus ring on your lens to shift the shallow depth of field around in your shot. Please note that since the camera is no longer communicating with the lens, autofocus will not be available to you. Put the lens in manual mode on the barrel to be safe - many lenses do NOT have manual override and forcing the focus ring while in AF mode can damage the lens.
Good luck and happy film-making!
on Jul 24, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
When I use camera in vr option I hear when I shooting in the end of shooting a litle clikc in camera and the screen pictures a little jumping on the screener.is it a normal or not. When I switch off vr...
The Vibration reduction system does move components inside the lens. If it makes a lot of noise you are better off turning it off and using a tripod. The VR system will move lens components to counteract your motion. The steadier you hold it (camera and lens) the less noise. On small Coolpix cameras the sensor is moved to counteract the vibration while it is hand held.
Oct 01, 2017 | Nikon 105mm f/2.8G ED-IF AF-S VR...
SONY A350 when turned on and off makes loud vibrating sound
Hi, I have exactly the same problem. The vibrating sound happens when the camera is turned-on or off. It looks like the camera is auto-deploying the anti-dust functionality and the vibration tries to shake-off the dust on the sensor. But I tried cleaning up the insides.. no luck. Would appreciate any tips on resolving this issue.. thanks, KP
Jul 09, 2009 | Sony Alpha DSLR-A350K Digital Camera
Trouble shooting my GR- DF550 vidio camera
mine is in safe mode 3 too and it won't go away. It's over a year old and not worth $$$ to fix. It's time to move up to a HD hard drive video. I suggest you too.
Jan 20, 2009 | JVC GR-DF550 Mini DV Digital Camcorder
NO SOUND
Hi There, Put mode control to shoot video, go into the menu and set the option to turn on the mic.
Thanks, mr cicmo
Dec 25, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
Dec 10, 2007 | Sony Cyber-shot DSC-T100 Digital Camera
Flashing HI
there is a flexible ribbon cable carrying signals from camera body to the lense assembly. Due to regular use it gets worn out, thus it gets broken and is not able to perform the task for which the camera has given the signal. in your camera also the same flex cable is broken. Get it changed at some good repairer
Oct 26, 2006 | Pentax IQZoom 928 35mm Point and Shoot...
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Minolta Maxxum 5 QD 35mm SLR Camera Logo
77 people viewed this question
Top Minolta Photography Experts
TC CAMERA REPAIR.Com...
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
