Question about Tomtom ONE v3 Car GPS Receiver
When driving with my tomtom turns its self off
When driving with my tomtom it turns its self off even when charging and then wont turn back on. this always happens after about 1 hour
It is (most often) the problem is in Safety Preferences'
Tap 'Safety preferences', then 'Done', then "done" again, then 'Done" again, then select 'Never' for "Turn Off Map Display'
Posted on Jun 24, 2009
    Problem Solver:
  • 15 Answers
I had the same issue and it was a defective power cable. Try to borrow one and if that fixes it, bingo. If not, it is an internal issue and must be sent back for service.
Posted on Apr 24, 2009
My tomtom one wont turn on.
there is a reset on that which you will need something small-paper clip works really well-to push in. Pop your memory card out and push in, then hot reset-good luck!
Nov 17, 2011 | Tomtom One GPS
Tomtom sav nav 910 wont turn on even after pushing reset button with paper clip as recomended. It is fully charged. Any other suggestions
Hallo! Try this: press reset +poiwer on for 20 secs, release reset but keep pressing power 20 secs, it should power the light on, very fast to connect to computer in this time, because it stais on 10 secs, open it like a map, backup ALL data in a new map, format the device, connect to TomTom Home, make the upgrades, copy the maps Maps and Voices back to your GPS.
May 12, 2011 | Tomtom GPS
Tomtom wont come on, tryed the reset still wont work, it has been chargeing for three hours
You battery is dead. Even though it is saying charging, your battery is not accepting the charge.
Nov 26, 2009 | Tomtom ONE GPS Receiver
My tomtom lost signal today it has not come back.the model i have is tomtom one 125. the blue arrow is not on the correct street.my tomtom is only 6 month old
I am tempted! yes here goes Your signal wont come back, your signal wont come back ( Old Tune of my boomerang wont come back)
It probably wont if the battery is flat , so first try charging bthe battery before turning to map programming. If that doesn't work then expect the worst.... you have damaged the SIIRF chip which is the chip that contacts the satellites
Very expensive to reapair cheaper to buy a new GPS generally
tomtom are notorious for this problem, but most times its caused by user abuse of overcharging or starting the car with the GPS plugged to DC spikes are common even though they dont blow the fuse in the charger plug. Even Mobile phones should be plugged after the engine is started. none of the GPS Distributors othert than one wilkl tell you of this money spinner. Next time aroumd you may want to consider an ALTINA see Marbella Australia and also read their FAQ on caring for your GPS
Jun 29, 2009 | GPS
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
The screen doesnt turn on but it charges fine
yes tomtom has it;s own hard drive maybe youre missing a peace try to contact the manufacture
US: 1/
phone_support.jpg 866-486-6866
May 14, 2009 | Tomtom ONE 3rd Edition GPS
My unit will not turn on
if you have previously used the reset button ( or maybe even if you have never used it ) , make sure the little rubber cap that covers the button is allowing the reset button to spring back up. my reset button was being constantly held down, and quite possibly was causing an intermittant reset press during driving. take a flashlight and check before sending it back/in for repair. when depressing the reset you should feel a very small click, if you don't feel it, then your button is stuck- use a needle to move/remove the rubber cap and allow the button to return to its unpressed state. hope this helps somebody out there...
Jan 28, 2008 | Tomtom GO 910 GPS Receiver
Go 710
Hook the Tomtom using the USB cable to your computer. You should see the Tomtom drive under My Computer as a drive letter.
Backup all data from the Tomtom to a folder on your computer. Now select the Tomtom drive and right click, select properties, select tools, and then Check now. Allow the computer to fix any problems with the Tomtom drive. Once this is completed. Remove the USB cable and do a reset. Now turn on your Tomtom and it should work.
Dec 26, 2007 | Tomtom GO 910 GPS Receiver
Tomtom 700 turns then turns its self off again
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Sep 29, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE v3 Car GPS Receiver Logo
170 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
