Question about Samsung SyncMaster 172N 17" LCD Monitor
Samsung 172n monitor
I just got a used samsung 172n cheap and for the most part it works fine. I do notice that there is some 'ghosting' of the vertical lines. what I mean is that I see a few echos or ripples of the image which decrease in intensity to nothing and appear to be equally spaced. any ideas? it shows up using two different Dell sx270s, (which I don't see on my CRT monitor) I have a dvi to vga converter on the computer and a 6 foot vga cable. Thanks in advance. Ned
  • 1 more comment
  • nedo Sep 27, 2007
    Cable and adapter are common between lcd and crt, and I have another lcd which also does NOT display the problem, so, this isn't a good solution.
    The problem is in the Samsung.
    Thanks!
  • nedo Oct 03, 2007
    I would not have beleived it if I had not seen it. The cable, with this LCD ONLY, causes this problem. Change the LCD, no prob, change the cable, no prob. Thanks Mukhtar, you were right all along.
  • Anonymous Oct 30, 2008
    splash
    President:
  • Samsung Master
  • 2,022 Answers
First you try with direclty connect to cpu without any convertor and extension cable and see if it work that mean problem with your convertor or may be the cord. if it not showing any changes show it service personnel. bye
Posted on Sep 25, 2007
SOURCE:
Ghosting lines on a samsung LN40A630M1F
The TCON Board or the LCD panel is faulty. Can confirm only by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 16, 2016 | Samsung Televison & Video
I'm back again after about a month away. Back to my problem, horizontal lines and/or interference make watching my Samsung 52" flatscreen impossible. TV is 5 years old. A limited time recall has passe
The TCON board can give you both Horizontal and Vertical lines, it is real easy to fix and fairly cheap. The most I have had to pay for any TCON board has been $45 plus shipping. Mostly what goes bad on these boards are the IC, a part that costs around $5.00 but requires micro-soldiering experience and tools.
Jan 01, 2015 | Samsung Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Toshiba 40xv640u vertical ghosting
This will require a technician to resolve with some specially equipment.
May 14, 2012 | Computers & Internet
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Oct 30, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Samsung SyncMaster 172N 17" LCD Monitor Logo
220 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
